Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 07-09-2006, 02:43 AM   #1 (permalink)
Fuel Drip From Water Drain How can I Fix??
I have a Intermittent Fuel Drip from the Water Seporater Drain Tube and I can Hear the fuel pump Refilling the Filter Housing On First Starts, Is There a Seal I can Replace or Do I Have to Spend $55.00 at the Stealer For a Complete New Filter/Seporator Housing?
99 (12/98) F-350 XLT, CC, LWB, 4X4
Stock Turbo (12/98)
3.73's
Stock Exhaust (No Muffler Y'ed To Twin Stingers Exiting Under Rear Bumper)
DIY Tymar
AutoMeter Piller Mount Pyro and Boost
4" Lift ?
35's on 10" Weld Wheels
Single Steering Stab.
Billet Tube Grill w/Bumper Insert
Bushwacker Flairs
Bug Deflecter
Wind Deflecters
Cab High Canopy (Paint Matched)
Tinted Widows all Around
Color Metalic Blueple
After market Cup Holders (Stock Cup Throwers Still In Place)
skykam is offline
Old 07-09-2006, 08:24 AM   #2 (permalink)
Re: Fuel Drip From Water Drain How can I Fix??
Couple of things, put your truck info in your profile signature so whey someone quotes you it won't pick up all the equipment information just what you commented on. You might get a valve assembly at the dealer for 55 buccks but not " a Complete New Filter/Seporator Housing?" If your fuel drain line is just losing a few drops then it is not draining the fuel cannister. That "refilling" is just your pump cycling on and pressuring up the system when you turn the key on. However, you need to stop that messy drip. There are two o-rings in the drain valve that commonly leak. Some here have used a rubber o-ring from Home Depot, two will cost you less than 5 bucks. I didn't know that at the time I bought an o-ring kit from the dealer, every o-ring in the cannister and valve, rated for diesel, for 30 bucks. But I needed the o-rings for my stock regulator fittings also. 106
Oneof6 is offline
Old 07-09-2006, 10:58 AM   #3 (permalink)
We replaced the ones on a friend of mines truck a while back. He bought them from one of the sponsors here. It only took about 15 minutes and a torx T-15 if I remember correctly.
99.5 F250 4x4
2000 Excursion 4x4
http://community.webshots.com/user/mmsafd
mmsafd is offline
