Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 05-17-2007, 11:21 AM   #1 (permalink)
Gas in Diesel tank
My buddy filled up yesterday in his 6.0 and there must have been gasoline in the diesel tanks. He filled up about 24 gallons. Truck started sputtering etc....
He made it home then siphoned out all the fuel. It smelled like gasoline.
Besides changing out the fuel filters and topping off with fresh diesel what should he do?
early 1999-6/98, crew cab, F250, short box, 7.3, 6 speed, 4WD, 3.73, bilsteins, AIS
12pack is offline
Old 05-17-2007, 11:51 AM   #2 (permalink)
Re: Gas in Diesel tank
He should get a lawyer. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Michael Hughes ~ www.SPL2K.com
2005 F-350 6.0 4X4 CC DRW King Ranch
2000 F-350 7.3 4X4 CC DRW Lariat LE
SPL2K is offline
Old 05-17-2007, 08:47 PM   #3 (permalink)
Where was this? I am in Westchester also..
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Scottb NY is offline
Old 05-17-2007, 11:25 PM   #4 (permalink)
Where do you siphon 24 gal of gas to? Maybe we don't want to know...
Run some Staydine in every tank for a while and he might be OK. The injectors will be the first thing to go if there are any problems.
Please visit www.roncartersucks.com
function12 is offline
Old 05-18-2007, 11:26 AM   #5 (permalink)
The gas can be used in 2 cycle stuff like chain saws & power trimmers. Might be able to use it in an old lawn mower. Does he have reciepts? Was the pump marked diesel? If so he should be able to re-coup the cost of the fuel, and may save a few others from the same mistake.
If he used the wrong pump, oh well - its only money.
OMCUSNR is offline
Old 05-18-2007, 11:39 AM   #6 (permalink)
Albin's Avatar
My Photos: (24)
This is why I keep all my receipts when buying diesel and pay with a credit card - there's no question when I was there and what I bought.
Al
'06 F-350 SRW 6.0 PSD
Albin is offline
Old 05-18-2007, 02:30 PM   #7 (permalink)
Also proves you paid for the fuel if you get stopped for doing a drive off. Don't ask
Early 99 F250 Crew Cab. South Texas Outfitters grill guard and bumper. Rhino linered bed covered by a SnugTop Snuglid. Homemade Tymar. Rockford/Fosgate speakers. Nitrogen filled tires and a quiet torque converter. 98 gal bed mounted aux tank. PIAA pencil beam lights Otherwise quite stock.
Airplaneguy57 is offline
Old 05-18-2007, 04:56 PM   #8 (permalink)
Band_Member's Avatar
I'm the one it happened to last Tuesday on the north fork of long island. I haven't been able to get on the net since.
The pump was marked diesel and the gas jockey filled it. I got a reecipt. Apparently someone either dumped gasoline into the diesel tank in the ground or the delivery truck was filled improperly.
He put 24 gallons of gasoline (presumably mixed with diesel) into my tank which already had 14 gallones of diesel. So I figure I had a roughly 3:2 mixture. Thank God it wasn't 36 gallons of straight gasoline.
I first noticed a rev in the engine when the torkshift shifted very soon afterwards. Then some hefty romping at low idle and coming off a stop. Thought I got a bad batch of diesel and figured changing my fuel filters would be required.
Drove appox 100 miles back home before I knew it was gas. Cracked the water seperator on the HFCM and immediately smelled the gas. [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Pumped out the tank into jerry cans and have been burning it off mixing it gradually with the gas in my other 2 suv's. A friend took 15 gallons to do same.
Filled a 5 gal jerry can in town with diesel to get the truck there from my place. Was smoking like crazy on the way. Then filled up top to total 37.2 gallons so figured I got most of it out. Put in 2 qts of marvel mystery oil in with the fuel.
So far have driven it about 75 miles and all is fine. I jumped on it a few times from a dead stop to see if I could break it. Heck if the engine is going to break I'd like it to happen now.
The gas station owner said to send him the bill and he'll make good. Fuel, filters, marvel mystery oil = $200 (Diesel is $3.54 a gallon here).
I remembered reading about this happening to someone else and that's what tey did. They also advised not to bring it to the dealer which I think is really good advice.
This was the first time that I did not pump my own fuel. In a way I'm lucky that the attendant did. The reciept specifies which pump # and diesel. So it's irrefutable. From now on I do a sniff test when I start pumping diesel into my truck .
Cant take anything for granted anymore. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
05 F250 xlt 6.0 torqueshift 4x4 sc lb stock
Band_Member is offline
Old 05-18-2007, 05:23 PM   #9 (permalink)
This is exacty the reason I go to truck stops and fill my truck myself.
2005 F-350 LARIAT 6.0 PSD SRW AUTO FX4 (removed) CC SB White, International emblems, Tow Command, Upfitters, Line-X, ScanGauge, Tomtom, XM, S&B w/Zoodad, Dieselsite coolant filter (w/RMI-25) and braided 4x4 lines, Mag-Hytec trans pan & diff covers, Fumoto oil valve (Rotella T), Knurled HFCM drain plug, Britebox, EZ-Down tailgate, BedStep, MBRP 5" cat-back (6" tip), Putnam class V hitch (Custom Texas star & horseshoe hitch cover), TransferFlow 30 gal toolbox tank + 46 gal midship tank = 76 gals. total with Stanadyne Performance additive... the rest is all stock you nig nogs. 41k miles.
Waiting for "BigTurbo" to help me install: Dieselsite Trans filter kit.
ljr869 is offline
Old 05-18-2007, 05:35 PM   #10 (permalink)
Smoke em if you got em.
The closest "truck stop" to me is upstate about 150 miles from here.
Old 05-18-2007, 07:42 PM   #11 (permalink)
and folks thought I was crazy for always sniffign the nozzle when filling up. I think you are taking this quite well. I wonder what the station will do with 5000 gallons of unsellable diesel? you might want to publish the station name so you local bretheren can avoide it for a while until he sells off all that bad fuel to tourists...
All things in Moderation accept ACCELERATION!!!!
Zip ties... the duct tape of the new milenia!
truckosaurus
2001 F250 Crew, 25,000+ miles, PSD, 4X2, ProComp 6" lift, Short Bed, SCMT, Tymar set up, BTM, ISSPRO Pyro, boost, and Trans Gauges, in tank mods and harpooned, 28" air horn w/ on board air and tank also full set of train horns! 6 gallons of 150 PSI air. Prodigy, Draw tite Signature series 18K 5'r hitch. TTM
2005 wildcat 29RLBS 5'r, parallel EU2000i's
2003 Explorer, EddieBower, V8 4X4
2003 Explorer XLT, V8 4X4
2002 XR50
2001 PW50
taxgod4u is offline
Old 05-18-2007, 09:03 PM   #12 (permalink)
Texrob1's Avatar
Send a message via Yahoo to Texrob1
" I wonder what the station will do with 5000 gallons of unsellable diesel?" They can sell It back to a refinery as Transmix & start the process all over again, to refine it back into gas & diesel.Trust me it will not go to waste. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
Texrob1 is offline
