Gear lever loose on automatic trans, rattles - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-24-2005, 04:38 AM Thread Starter
My 2000 Dually has a gear selector lever that is loose and the rattle is annoying. It is an automatic transmission. It works fine, just rattles.
I'm retired and like to try and do all my own repairs. Would appreciate any help.
mcdlt
2000 F350 crew-cab dually, DP-Tuner Xcal2, Jody's 40hp tow & 80hp economy tune, coolant filter, AIS, Zoodad, Walker BTM, Reese 15k 5th wheel hitch, 110 gal aux fuel tank
mcdonell8 is offline
post #2 of 5 (permalink) Old 03-24-2005, 09:22 AM
Re: Gear lever loose on automatic trans, rattles
I believe I had the same problem that you are talking about. There are two bolts at the bottome of the column that came loose, I don't remember the exact size. I had one that was completely gone, and the other one was only in by a couple of threads. I got new ones, used lock tight, and they have been fine ever since.
John
jbutch83 is offline
post #3 of 5 (permalink) Old 03-25-2005, 10:25 AM
JimTJr's Avatar
My Photos: (20)
What Jbutch said,, crawl under the dash,,and wiggle the lever..you will see what is loose.. mine did too.. reinstalled the bolts with a couple drops of locktite,,and fine ever since.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #4 of 5 (permalink) Old 03-29-2005, 03:09 PM Thread Starter
Re: How to stop Gear shift lever rattle (auto trans)
Thanks for feedback but I did not have much success. I crawled under the dash and jiggled the gear shift lever. Everything look tight under there.
I did take a star type screw driver and was able to slightly tighten the two bolts on the bottom of the columm. However it still feels loose near the top at the lever itself. I guess the steering wheel will have to come off and maybe I can see what is going on.
Any ideas or suggestions will be appreciated. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
mcdlt
post #5 of 5 (permalink) Old 03-29-2005, 06:08 PM
fordmastertech's Avatar
You will probably find the shifter tube bushings worn or the shifter tube hole where the pin goes to hold the shift lever in. You can see this by removing the steering column trim.
FMT
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
