You can't use the front rotor in the rear because the emergency brake is the drum brake style that runs along the inside of the 'hat'. The front doesn't have this. 1 extra machined surface needed.
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
