Head Lights not working!!! - Diesel Forum - TheDieselStop.com
Old 03-03-2005, 08:33 PM   #1 (permalink)
I am running 80/100w headlights and they quit working today. The highbeam light came on on the dash and i have no power to the pig tails at the lights. The bulbs are good the fuses all apear to be ok. The lights burnd out the pig tails so i got some new ones and now i have no power to them. i have replaced the pig tails w/ new ones and still no power. I heard a buzzing from under the dash on the passenger side but dont know what it was coming from... please help me i have to drive at 5:30 am tomorow morn... Thanks in advance
JT
2004 F350 6.0l, auto, 4x4, 250,000km
minesbigger33 is offline
Old 03-03-2005, 10:02 PM   #2 (permalink)
My Photos: (21)
Re: Head Lights not working!!!
The day time running lamp relays are located behind the glove compartment. There are two relays on their own relay block. Swap them with each other and see what happens.
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 03-03-2005, 10:47 PM   #3 (permalink)
i tryed swaping them and it worked. There is three relays two small and one large I swaped the small relays and it worked again. What is the other relay for? And do i need to worrie about replacing the relays for something a little stronger? seeing that i am running stronger lights? Thanks for the post i mannaged to find it b4 i read this but i am glad to hear some one else knows where to look
JT
Old 03-06-2005, 07:57 PM   #4 (permalink)
Any IDEA's about this....my regular headlights work fine, but when I flip the switch to turn on the bright lights, both regular and bright lights go off...leaving no headlights at all. This usually happens after a rain. Generally 3-4 days later everything is okay again????
Any ideas are appreciated [img]/ubbthreads/images/graemlins/confused.gif[/img]
2012 F350 SD CC Lariat PSD Leather - 3.55 gears - E-Lock - 6 Speed Auto...Pullrite 16K Super Glide, 2010 Jayco Designer 35 RLSA 5ER
2005 F350 SD CC Lariat PSD Leather - 3.73 gears - 5 Speed Auto...Pullrite 16K Super Glide, 2010 Jayco Designer 35 RLSA 5ER
1999.5 F250 SD SC - AFE Stage II intake, TS Performance 4 Position Chip (50-75-100-125), 4" Catback exhaust, AutoMeter Pillar mount gauges. Tru-Cool Max Transmission Cooler, Firestone 2330 Air Bags. Pullrite 16K Super Glide, 2005 Wilderness Advantage 295 RLTS 5er
joggerman is offline
