General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
remove the fuse panel reach up , and realease it from the back.
that is how you do it on the ealier models, it actually has some kind of slide that pulls the tabs in, but doubt you will get it the first time, after you have it out once, it is easy.
early 99 f350 4x4 crew cab
work in progress
You can easily pull that side of the dash out of its clips and get enough room to get your hand in behind the headlight switch and push it out of its socket. You don't have to pull the whole dash off.
2005 F-250 CC/SB 4X4, 6.0L PSD-Torqueshift
med wedgewood blue,towcommand,upfitter switches
5"procomp lift, 35"tires, 4.30 gears
BCP mod, LED taillights, 4"Banks exhaust, Harpooned fuel tank,
Accufab intake elbow, ARP Headstuds
Pioneer avic-D3 with backup cams and ipod
Pulling the dash is easy enough... once the radio is out. Two small bolts and pull.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum. Winter Operation (How I Do It) Hard/No Start? Check here first
is this the same as like a 2001 model? if so its all in the knob. Really easy to do. I will post the instructions if you would like?
the only problem that can happen is the faceplate of the switch will pop out.... That is what happened with mine. I tried to peal it out and out came the faceplate while the back and main part of the switch remained lodged in the dash.... So just peal it back a little and you will see. But I am pretty sure you can just drop the fuse panel below and pop it out from the back...
01 F350 CC LB 4x4 SRW,(w/forged rods), 6" Lift, 37"ToyoMT, 22"MKW M19's, Mini Mes, GTP38R, BTS Chip, Spearco, Headstuds, 910 Springs, 4" exhaust, Coolingmist Water Injection, BTS Tranny, 6.0 Trans cooler, 05' Conv. w/ Mirrors, AFE2, Truspeed, Isspro Guages, ORU Diff Covers, Hella 500s, Transfer Tank, ITP Boost fooler, AMP powerstep, Heat Extractor Hood, custom paint, billet badges, Train horns, Recon lights, strobes!
4/8/08 402hp, 824 ft-lbs Mustang Dyno
8/2/08 14.39 in the 1/4 @ 93.5mph on 37's @ 8950 lbs
+1.........
05 F350 6.0L SC,LB,SRW
04 RX-8 1.3L Touring
03 KTM 525 EXC Racing
94 RX-7 1.3L PEP
Here's the magical procedure for the 2000 models, might work on later ones:
Removal
1. Disconnect battery ground cable.
2. Turn headlamp switch knob to the headlamp ON position and pull the knob out.
3. Insert a thin tool into the slot at the base of the knob to release it and pull the headlamp switch knob off.
4. Position the knob with the back end toward the headlamp ON position and install. (Rotate 180 degrees)
5. Turn the knob counterclockwise until the back of the knob is in the OFF position.
6. Turn the headlamp switch knob clockwise fully, remove the headlamp switch (11654) from the instrument panel and disconnect the electrical connectors.
Installation
1. Follow removal procedure in reverse order when installing the original switch.
2000 F350 7.3, Auto, Lariat. John Wood modifications: transmission, Airdog, ITP reg return, AC single shot injectors, DP Tuner, live tuned.
thanks guys sorry about not getting back sooner (flu issues) I thought the newer models (03+) did not come apart like the previous years. Will investigate and attempt all the ideas before pulling the dash. I know pulling the dash is not a big deal, just trying to go the least invasive route. thanks
