Headlights - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 03-19-2017, 05:59 AM Thread Starter
Headlights
Hey everyone,
Lighting technology has come a long way since my truck was made in 2003 (so has electronics in general). I'm looking to replace my headlights, fog lights and rear lights with something that performs better.
Shopping around online I've found a few products. Before I take a stab in the dark and drop some money on a product, I thought I would seek current knowledge here.
Have any of y'all done this maintenance on your truck? I'm looking for advice/opinions on good products. Also, if you know of something that did not work well, I'd like to know about that too.
Thanks in advance,
Todd
2003 F350 6.0L crew cab 4x4 dually
2002 Indian Chief Deluxe
te805 is offline
post #2 of 3 (permalink) Old 03-19-2017, 06:57 AM
ArcticDriver's Avatar
Todd,
Until you get some good responses, you can use the magnifying glass in the upper right corner and search headlights. it is a popular topic.
I want sealed beam headlights
Brighter headlighs
Aftermarket LED headlights
What is your price range?
2000 F-250 4x4 SC SB 7.3 PSD w/4R100. 160,000 miles.
NOS Black CPS. Rebuilt Fuel bowl w/gold spring, 6.0 Cooler, Walker BTM, Stancor GPR, AIH Delete, ScanGauge II, AIC, 2002 Headlights, Bilstein 4600, Marinco Mod, Cupholder Upgrade, B&W Turnover Ball, Michelin LTX
2002 F-250 4x4 CC SB 7.3 PSD w/4R100. 154,000 miles. (purchased 02/17/17)
ScanGauge-II, B&W Turnover Ball
ArcticDriver is offline
post #3 of 3 (permalink) Old 03-19-2017, 05:00 PM
I tried some 9007 replacement LED headlight "bulbs" by Lifetime LED in my 2008 Ranger in the stock headlight assemblies. I liked the brighter white color because they REALLY make deer stand out, and I do about 80% of my driving in the dark. They also spread a lot more light out to the sides of the road too; again, an advantage when you're trying to see the deer before they decide to commit suicide-by-truck. However, they seemed to lose some of the "reach" at long distance that the halogen bulbs provided.
I ended up taking them out of my Ranger because they were throwing a weird interference that messed up my TPMS system. Lifetime LED replaced them under warranty (even though I had asked for a refund) but I have not reinstalled them. I keep meaning to put them up for sale on one of the boards but have not done so yet. On my Ranger (and eventually on my Powerstroke) I rebuilt the headlight harness with heavier wire and used Philips Xtreme Vision bulbs, which made quite a difference over the factory setup.
If you can do with a little less distance to get more spread and a whiter color, something like this may be worth a try for you. Needless to say, the TPMS issue will not affect your truck. Maybe someone else will chime in with a better solution - I'm always looking for better light, but I sort of need the distance, too.
Good luck!
Regan
2003 F250XL 4WD 7.3L Crewcab LB (built Oct. 2002- one of the very last 7.3's!); Toreador Red; 6 speed, 3.73 LS; Camper package; Receiver hitch; Prodigy brake controller; Gauges: Pyro, Boost, Oil Press., Temp. switched to trans/oil/diff.; case vent mod; coolant filter; prepump Dahl filter/ separator with heater; prepump and in-tank mods; Tymar intake system feeding an ATS housing; Walker BTM; Magnefine trans and PS in-line filters; Ultraduty aluminum diff. cover; Hayden extra trans. cooler; Mobil 1 ATF in PS, trans and transfer case; aluminum running boards; Big Tex grille guard/ deer deflector; aluminum camper shell. Canoe hauler and camping truck extraordinaire. Don't want a hot-rod, just want to make it last forever!
Woodtroll is offline
