Headlights always on - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 06-15-2017, 01:42 PM Thread Starter
I'm just finishing up swapping my 05 6.0 into an 06 crew cab. crew cab was gas, but I swapped every wiring harness. Everything seems to work so far, just one issue i can't seem to resolve. Whenever the batteries are hooked up, the headlights stay on, and the high beam indicator is on. Doesn't matter if the key is on or off, truck running or not. I've tried unplugging the headlight switch, and three fuses for the headlights, but nothing seems to kill them. Ive been back over the harness a bunch, and nothing is pinched or chaffing. Lights worked fine before the swap. Any ideas? Thanks
wmerrill1 is offline
post #2 of 4 (permalink) Old 06-19-2017, 11:51 AM Thread Starter
After messing with it a bit this weekend, i am still stumped. The only way i can get the lights to go out is by pulling the 30 amp flash to pass fuse.
post #3 of 4 (permalink) Old 06-19-2017, 04:08 PM
klhansen's Avatar
My Photos: (180)
I believe the flash to pass circuit goes directly to the multi-function switch, which then sends power to the headlights, whether it comes from the headlight switch or the flash to pass circuit. So my guess would be that your multi-function switch is mal-functioning instead of multi-functioning.
I would check there for a solution. Might be just a coincidence in timing with your engine swap.
), AIS,
regulated return,
klhansen is offline
post #4 of 4 (permalink) Old 06-20-2017, 09:31 AM Thread Starter
Thanks. Is there a procedure to test this? Anything can happen, but I hate to just throw parts at it whereas it was previously working fine.
