Heater/AC Blower only works on high?? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 10-04-2006, 10:23 PM Thread Starter
My Photos: (18)
I have a 2003 f-350 that the blower motor only works on high, meaning that when the selector is in any other position it does not turn on but once in high it blows on high speed. Does this mean that the selector switch is bad or is there seperate windings for each speed? Any help appreciated.
2002 F-250 7.3L 65,000mi, AFE stage 2, Magnaflow turbo back
Tekonsha Prodigy Brake controller, Line-X Liner, Extang RT Tonneau, B&W Turnover Ball w/5th Wheel Companion hitch. Adrenaline HPOP on order.
mkopy1800 is offline
post #2 of 7 (permalink) Old 10-04-2006, 10:47 PM
mksmipalla's Avatar
Re: Heater/AC Blower only works on high??
broblem is most likely the blower motor resistor. it is next to the blower motor in the evaporator case under the hood. has 2 8mm screws holding it in place. ck the first and see if the plug to the resistor is burnt.you may have to change the plug also. it is a very common problem.
2003 7.3 psd. 4" stainless exhaust,afe stage 2 intake,banks big head wastegate,zoodad mod,ccv mod,diablo programer,air intake heater delete,4.10 gear,cooling sys filter,hx crossover line, gauges,203* thermostate,brv.
mksmipalla is offline
post #3 of 7 (permalink) Old 10-05-2006, 05:39 PM Thread Starter
My Photos: (18)
mko3psd you were right on. I removed the resistor then ohmed it out. turned out to be what looks like a diode was open. Just decided to remove it and solder in a small copper jumper. Works like a champ.
post #4 of 7 (permalink) Old 10-06-2006, 10:22 AM
My Photos: (9)
Not a diode- Its a FUSE.
Replace the resistor assy.may be playing with fire for real
2005 F-350 CC SWB SRW Harley; 2004 F-350 Chestnut/tan 4X4 King Ranch CC SWB SRW 2004.25 6.0 PSD
Past PSD's All 4X4
1999 F-250 SC SWB 10-98 build
1999.5 F-250 Lariat
2000 Excursion Limited PSD
2002 F-350 CC SWB Lariat
2002 Excursion Limited Ultimate Premier
2004 Excursion Limited 6.0 POS
Son's F-250 SC SWB PSD
2005 F-350 King Ranch CC SWB 6.0 POS
Nat Lancaster is offline
post #5 of 7 (permalink) Old 11-20-2010, 05:50 PM
gixxerkid3's Avatar
Well, i am experiencing the same problem and I have a 2006 6.0l. If someone has a picture of the exact resister that would be great. Heater blows on high only.
It started out by blowing on high no matter what I did. I could change locations that the air blew out (floor, floor /defrost, etc) and even in the "OFF" position. It would not shut off. I drove home, shut the truck off and let it sit for a while and now it just blows on high only. Heat and A/C work fine, can change locations, just cant turn down the blower.
Pictures of the resister would be great. PLEASE HELP.
2006 F350 Lariat FX4 bone stock and staying that way. LOL, as of April 2013, ARP Studs, HG's, (got 185K out of it before they lifted). LOL-SOLD
2002 F350,7.3L, crew cab, long bed 4X4.Leveling kit, Superchip, gauges. Sold and I miss it.
2008 HD FLHTCU with ThunderMax and Rineharts.
gixxerkid3 is offline
post #6 of 7 (permalink) Old 11-23-2010, 02:49 PM
I'm having problems with my HVAC fan but my case is even more odd - it won't work on low (position 1). The fan works fine on every other speed but low. I figure it's probably the fan motor itself but wanted to see if anyone else has encountered this issue.
How much effort is it to change the HVAC fan on the SD?
'99 F350 XLT SC 4x4 6 spd PSD
mgyip is offline
post #7 of 7 (permalink) Old 11-29-2010, 01:45 PM
My Photos: (19)
mgyip, yours isn't that odd, I've got the same issue also. I haven't gotten around to digging through that part of the truck so again to anyone that may have pics to this fuse/resistor part, please post up!
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
