Heater control stuck on defrost - 2000 F250 Powerstroke - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 01-29-2007, 01:25 PM Thread Starter
My heater control is stuck on defrost on my 2000 F250 Powerstroke, or rather the control on the dash turns OK, but the results are that it only blows air on the windshield through the defrost port. I can't get it to change air output to floorboard or dash ports. Other controls such as temperature control and fan speed work OK. Any ideas what is wrong and how to fix it? Thanks in advance for any help.
tjc1989 is offline
post #2 of 6 (permalink) Old 01-29-2007, 01:29 PM
Re: Heater control stuck on defrost - 2000 F250 Powerstroke
That's usually a vacuum problem. Either the little pump on the passenger fender/firewall under the hood has gone bad, or a line has fallen off somewhere, or (in a lot of cases) there's a cracked line down near the ESOF hubs that is letting all the vacuum escape.
The default position of the vacuum-operated flaps is defrost.
Duncan
The 1997 F250HD Crewcab:
The 2000 XLT Excursion <font color="red">(SOLD)</font>:
The 2003 F250 Crewcab 6.0L:
The 6.0L Bible:
The 6.4L Bible:
frobozz is offline
post #3 of 6 (permalink) Old 01-29-2007, 02:09 PM Thread Starter
Thanks, that sounds like a good starting point. I'll go and check it out. I am assuming its electrically powered. Does it have its own fuse? Pardon my ignorance, but what is an ESOF hub?
tjc1989 is offline
post #4 of 6 (permalink) Old 01-29-2007, 02:21 PM
Electronic Shift on the Fly- ESOF 4wd.
2013 250 Lariat CCLB, 6.7, 4WD, all but the roof, Amp Research Power Steps, BedRug, ARE cap, power tailgate lock.
2000 250SC,4WD,4R100,3.73 rear,loaded, Leer XL160
fxdwg is offline
post #5 of 6 (permalink) Old 01-29-2007, 02:56 PM
Here read this thread:
http://forums.thedieselstop.com/ubbthrea...e=2#Post3165713
01 F350 Lariat 4x4, ECSB SRW, Magnaflow Tuner SS muffler delete exhaust, WW, boost fooler, Non-EBPV housing, DP Tuner F5 (40T, 80E w/ 80T shifting, 120R), AEM CAI, ZOODAD, AIH delete, Autometer Pyro/boost/trans. temp. gauges on A-pillar, leveling kit, 35x12.5 BFG ATs, 17x10 Incubus Recoils, 4.11 gears, chrome badges
04 ZX10R
9.959 @ 142 N/A 2006
9.895 @ 148 N2O 2005
05 BMW 325XI
Wifes car
SeriousasaStroke is offline
post #6 of 6 (permalink) Old 01-30-2007, 05:02 PM Thread Starter
That was it. No vacuum. I checked the pump and not working, and no voltage to it. That left a fuse, which was the culprit. So replaced it and its working OK now. Thanks again. By the way, mine is a 2WD and thats why I wasn't familiar with the ESOF term. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
tjc1989 is offline
