Heater not working, thermostat stuck closed?? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 04-08-2010, 11:29 PM Thread Starter
Recently it got cooler down here in TX and when i turned on my heater up all the way with full blast, nothing but cool air was blowing out. Yes, the engine temperature was in operating range between C and H. Im thinking thats the result from my thermostat possibly being stuck closed for whatever reason. Luckily, its hot during the day so i run the AC most of the time but just wanted to know due to my next problem; for some reason, the trans. temp. needle stays near the "C" range. I drive, say 20 miles with the engine hot but the needle only goes up 1/4 of the way and stays there instead of normally being in the center of C and H like usual. The two issues seem connected since it sounds like a problem that affects proper cooling and heating of the climate control and transmission. Anybody have suggestions???
viper_09 is offline
post #2 of 4 (permalink) Old 04-08-2010, 11:37 PM
tomjon's Avatar
similiar thread - I'll bet this is your problem , not the cooling system.
AC/Heat control problem, not the defrost though
01 f250 7.3 diesel Gone , but not forgotten
,x-cab,xlt,170k,...stocker , powerslots and hawks , Rotella ELC , Dieselsite coolant filter
69 Bronco 302 np435 , not enough tires, lift ,time or money.
tomjon is offline
post #3 of 4 (permalink) Old 04-09-2010, 10:30 AM
Is your upper radiator hose hot? If it's hot, the thermostat is not stuck closed.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
post #4 of 4 (permalink) Old 04-09-2010, 07:23 PM
A thermostat stuck closed would make the coolant hotter. Hotter coolant would make the heater warmer not cooler.
444-4D is offline
