Heavy Truck - Diesel Forum - TheDieselStop.com
Old 11-08-2012, 09:46 PM   #1 (permalink)
Supporting Member
Traildust's Avatar
My Photos: (9)
Heavy Truck
I just weighed my 02 F350 CC, LB, SRW, 4X4, 6 Speed. It has a B&W Fifth Wheel Hitch, my wife and me and full fuel tank, weighed in at 8,120 lbs. It just seems a little heavy to me. I just purchased a new Fifth Wheel with a pin weight of 2000 lbs. The truck has a 9900 GVWR, so I am going to be 220 lbs. over. Does the 8120 truck weight seem about right or is it on the heavy side? I haven't hooked up to the new Fifth Wheel yet as it's still on order but given these weights does it look like a set of Airbags are the future?
Thanks,
Bill
2002 F350 CC, LB, SRW, 4X4, 6 Speed. Hutch Pre-Pump and In Tank Mod, Housted T, Harpooned Tank. LL#8 Gone. EPI Flex Pipe. Scangage2. Towing 2013 Arctic Fox 27-5L 5th. Wheel
Traildust is offline   Reply With Quote
Old 11-08-2012, 10:04 PM   #2 (permalink)
RT
RT's Avatar
Maybe the previous owner was a diamond smuggler. Have you checked the door panels?
Seriously, though - that weight sounds exactly right.
SmokeyWren is the trailer weight guru - I'll ask him to look at your question and tell you what your options are.
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is online now   Reply With Quote
Old 11-08-2012, 10:33 PM   #3 (permalink)
yeah i have the same truck exc 2wd and with my ut trlr 16' it grossed at about 9500. i have put 10k or 5er and it pulled just fine. i think you should put the trlr on and drive it for a few mile and see how your truck sits with trlr on. if it sits good then i would not do airbags; if she sits lower than add load kits.
tickedoff36 is offline   Reply With Quote
Old 11-21-2012, 04:18 PM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Originally Posted by Traildust View Post
I just weighed my 02 F350 CC, LB, SRW, 4X4, 6 Speed. It has a B&W Fifth Wheel Hitch, my wife and me and full fuel tank, weighed in at 8,120 lbs. It just seems a little heavy to me. ... Does the 8120 truck weight seem about right or is it on the heavy side?
My '99.5 F-250 CC, LB, SRW, 4x2 automagic weighed about 8,000 before I tied onto the 5er. That included Rhino bedliner, toolbox full of tools and fluids, Reese 15k 5er hitch, Darling Wife, PuppyDog, and a full tank of diesel. Your 4x4 should weigh a few hundred pounds more than my 4x2, so if you haul the same tools and stuff that I do, then you're a coupla hundred pounds too light.
SmokeyWren is offline   Reply With Quote
