Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 07-08-2008, 12:16 PM   #1 (permalink)
Help !!!!! A/C Gone Wild
My AC is going from cold to hot in a 7 min rotation. Also my AC blows better than on max AC, though it has no effect on hot cold rotation just blows better. Had levels checked, everything is ok. Any Ideas ?
Bud
1999 F-250 4X4,Fun Fast , Lots of stuff, 175,000 mi and runs better than ever.
2008 SD Lariat, " Here we go again"
Dieselholic is offline
Old 07-08-2008, 12:24 PM   #2 (permalink)
A/C gone wild, is there going to be a video? Where are we going with this? I just could not resist.
02 F350 Lariat CrewCab Toreador Red/ Silver DRW AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 741,336 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 XLT SC DI DRW 5Speed 314,000
04 Grand Marquis LS sure wish it had a BTS!
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
HighwayPrisoner is offline
Old 07-08-2008, 12:26 PM   #3 (permalink)
Never thought of putting out a video !!!
Old 07-08-2008, 02:40 PM   #4 (permalink)
Not busting your bubble, but there are no "level" checks with A/C. Did you have the pressure checked? It sounds like you are a touch low on freon. Do you hear the compressor cycle on and off at all? Sounds as if the low pressure switch is shutting it down. This is called short cycling. You could also have a high side restriction that is creating high pressure and the high pressure switch could be shutting it off.
2002 F-250 Crew Cab Long bed 7.3 4x4. Edge w/attitude, Edge Evolution, whicked wheel, BTM, lifted sitting on 35's. Onboard Air, tank, train horns, air bags w/ controller. Custom AUX tank, Tonneau cover, Dual Din in-dash DVD/NAV.
02Boathauler is offline
Old 07-08-2008, 04:30 PM   #5 (permalink)
thanks for the feedback, yeah i ment pressure not level, you knew what i ment
Old 07-08-2008, 06:36 PM   #6 (permalink)
Pull the connector off the pressure switch and check the female pins inside the connector. Mine were corroded. Everything worked fine after I replaced the harness.
2OOO F-250 4WD Crew Cab, 192K miles, replaced brakes, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella T, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 07-09-2008, 10:20 AM   #7 (permalink)
I was not sure if you did it or some shop, but I knew what you ment.
Some shops are just stupid, and if they are using words like "level" take it to someone who knows what they are doing.
