Help: Dome & Cargo lights ON - Diesel Forum - TheDieselStop.com
Old 03-31-2009, 03:16 PM   #1 (permalink)
HoneyShucks's Avatar
Unhappy Help: Dome & Cargo lights ON
Always on. Sprayed all 4 door latches down with WD-40. Still on! Must I replace all latches? How do you remove the latch with window channel in the way? Anyone experience this before? I sure appreciate any help
2001 Ford F-250 PS, CC, 2/w drive short bed, auto(BTS upgrade), Banks Stinger Plus and exhaust brake, TurboSaver, HX,Hutch mod/pooned, K&N FIPK, Mag-Hytec trans and diff pans, Cyclone fan, doodad, Bilstein shocks, Air-lifts front and rear, dp-Tuner F-5 chip, Fleetrite/203therm, fuel regulator shim, GOS headlight harness/silverstars, Bob's coolent filter, Rotella Syn w/single by-pass.
HoneyShucks is offline
Old 03-31-2009, 09:23 PM   #2 (permalink)
Power locks work normal. Sure need your help why the dome and cargo lights stay on with all doors shut.
Old 03-31-2009, 09:33 PM   #3 (permalink)
klhansen's Avatar
My Photos: (169)
You just need to replace the door switch that isn't working. Probably the driver's door. Try that one first.
You might be able to troubleshoot it by pulling connectors apart. C218 (16 pin in-line located under the center of the dash) for the left side door switches. LH driver door should be on pin #2, black/yellow wire. LH rear door is on Pin #6, black/white wire. For the right hand doors, it would be connector C228 located behind the passenger kick panel. It's an 8-pin connector with the front right door on pin #3, black/pink wire, and the rear door on pin #8, black/white wire.
Not sure whether the switches ground when the door is closed or open (I'm guessing open), but if you pull both connectors and the lights go out, you'll know. Then look for the circuit that's open on the switch side of the connectors.
I haven't replaced a switch, so can't help there, but there must be a way to replace them, as they got installed somehow, and they tend to make that stuff as easy as possible for assembly line workers.
Hard or no-start? Check Here
Last edited by klhansen; 03-31-2009 at 09:49 PM. Reason: added wiring info (for 99-01 only)
klhansen is offline
Old 04-01-2009, 12:45 PM   #4 (permalink)
ferdman's Avatar
I know this sounds stupid but did you check the dimmer switch to make sure that it is not on all the way?
99.5 CC dually, wicked wheel, BD 6 pos chip, AIS, Zoodad & fender sleeve, injector rail cross over tube, adjustable wastegate, boost tube, 3 guage pod with pyro, boost & trans, Manual T/C lockup switch, fuel pressure shimmed to 65 psi.
85 mustang 1150 hp N/A 8.30s @ 165 mph on 10" slick.
ferdman is offline
Old 04-01-2009, 08:27 PM   #5 (permalink)
Man, do I feel stupid!!
Thanks, ferdman, from an old honeyshucks
Old 04-01-2009, 10:50 PM   #6 (permalink)
ferdman's Avatar
Your welcome!
ferdman is offline
