Ok my 2007 6.0 F350 has now been in the shop for a LONG while now. We are now beating our heads against the wall and need help!!!
Let the truck sit for 2 days and the thing won't start both batteries are dead. Charge them or jump it and it fires right up.
Alt. checked and it is low
Disconnect Alt. and it still draws batteries down in 2 days!
With test light hooked up for a draw test and pulling fuses for the Instrument Cluster and the break peddle position relay it would dim the light.
Now started test over again and the test light wouldn't go out until pulling the Tow Haul switch.
***!!! I have had a problem once or twice with the AC not coming on or the after market radio. But after turning off and on it would be OK. This issue has not happened since the draw has been taking place.
Could this problem be with the GEM Module?? Help please!!!
Sent from AutoGuide.com App
