help mechanic says i need to change altenator - Diesel Forum - TheDieselStop.com
Old 11-19-2012, 07:18 PM   #1 (permalink)
Exclamation help mechanic says i need to change altenator
I asked my mechanic to do a load test on my batteries and cgheck my starter and alatenator, he said low volts on my batts and my alt failed, when I jumped into my truck my battery gage was at 13.4 volts, thisv morning when I started it was at 11.9 then went up to 13.6,. All day was in that range,
Was this guy trying to rip me off
05 ford f350 drw 6.0 litre edge evolution chip
Bobby V is offline   Reply With Quote
Old 11-19-2012, 07:28 PM   #2 (permalink)
chuckster57's Avatar
I think your
Mechanic is trying to get you to pay for his Black Friday purchases. Take it somewhere else for a second opinion. Voltage in a 6.0 is sort of critical for the health of the FICM.
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
Old 11-19-2012, 07:44 PM   #3 (permalink)
My Photos: (35)
Your readings are some what my volt reading on the scangauge 2 was showing before I replaced it. Now that the alternator was replaced in the middle of summer the readings are above 13.8 and that is with all the lights on and heater going at full and setting at a stop sign....
I would say that yours is on the final legs and will need to be replaced.
I would shop around for some prices and what it would take for your self to replace the alternator and belt while you are at it, also check the pulleys.
2000 E350 7.3PSD, Hellwig Stablizer bar,140 Lightforce with covers, 55Watt High/Lows HID's (watch which company) , extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E Toyo Open Country, My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
Alaskapsdvan is online now   Reply With Quote
Old 11-19-2012, 08:00 PM   #4 (permalink)
Thanks for the replies, I'm looking for another good diesel mechanic just hard to find them in my area,
Old 11-19-2012, 08:05 PM   #5 (permalink)
Mark Kovalsky's Avatar
You don't need a diesel mechanic to diagnose an alternator.
Mark
Mark Kovalsky is offline   Reply With Quote
Old 11-20-2012, 06:05 AM   #6 (permalink)
I am with Mark. Any mechanic can change an alternator. In fact, most here do it ourselves.
Member # 23075 Reged: 07/18/02
2005 Excursion w/ 6.0L PSD - Edge Insight, RCD EGR delete, Turbo Drain/Blue Spring/Oil Cooler Updates, Dfuser Coolant Filter, 240amp alt, fumoto.
2008 FX4 F250 CCSB w/ 6.4L PSD - Edge Insight, H13 Bi-HIDs, custom coolant filter, fumoto.
rock_doctor is offline   Reply With Quote
Old 11-20-2012, 11:32 AM   #7 (permalink)
bobsherrie's Avatar
The voltage might be okay but maybe the alternator isn't putting out enough amps. That would account for the low batteries. I agree with Alaskapsdvan that your alternator is about done. They seem to fail often according to posts I've seen.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline   Reply With Quote
