How to aim '05 headlights?? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 05-11-2011, 11:32 AM Thread Starter
itorchedparis's Avatar
so I just did the 05 front end conversion on my 2000 7.3...I knew how to aim my old headlights, but I can't seem to understand how the 05-07 style lights are aimed....they are just held in with two screws on top and two on bottom....there are no aiming adjusters like that on the 2000 style one....anyone know what I'm talking about, or how to aim them?
2000
F250 7.3L Lariat, Crew Cab/Short bed 4x4. AFE stage II intake. Magnaflow 3.5DP/4" SS exhaust. Isspro gauges (EGT, Boost, Trans Temp) AIH Delete with riffraff boost fitting adapter, Foil delete, Muffler Delete, CCV Mod, Performance tranny from Revmaxx, Revmaxx stage 4 triple disc low stall torque converter, Revmaxx performance valve body with custom shift kit. 6.0 tranny cooler, ported compressor housing, turbomaster wastegate controller, garret high flow outlet, Non EBPV pedestal, dieselsite boot kit, Marinco mod, Fuel Bowl mod, HPX mod, Riffraff Frx, DP F6 tuner (60 tow, 80 econo, 120 race, High idle 1200, Drive Thru) Warn Hubs, Moog Balljoints, 08 tailights, 05-07 front end conversion, 08-11 rear end conversion, Line-xed rocker panels/wheel wells/bumpers
itorchedparis is offline
post #2 of 4 (permalink) Old 05-11-2011, 03:14 PM
There should be two torx style studs sticking up on the top that will adjust them. One of each side of the truck. And I have aftermarket headlights too.
06 F-250 x/c 4X4 sb 17" alloy wheels. Tri-fold tonneau cover, weathertech vent visor,Ford floormats and splash guards. HarleyD headlights, Duplicolor bedliner coated bumpers, 08 rear bumper and taillights, herculiner rocker panels, XM radio, bosch wipers, Recon smoked cab lights, Edge Insight w/EGT probe, winter front.
06/10 ARP studs, turbo back silverline, new head gaskets, new oil cooler, upgraded turbo drain, fuel pressure reg upgrade, coolant filter, high idle mod, harpoon mod, pre-pump spin on fuel filter,ELC coolant, 6.4 banjo bolts, CCV reroute.
Truck weight empty fueled up, 4440 Front, 3040 rear, 7480 gross. Hex VXCF4,
SCT w/customs tunes from Vivian at Quick Tricks and Matt @ gearhead
worldwide73 is offline
post #3 of 4 (permalink) Old 05-11-2011, 11:48 PM Thread Starter
Yeah, I just noticed them earlier today and adjusted them...they were about 2 feet high lol....my low beams were lighting up tree tops when I drove down the road
2000
post #4 of 4 (permalink) Old 05-12-2011, 07:09 AM
Thanks for info..........
abbyjhon is offline
