how to change front marker lights - Diesel Forum - TheDieselStop.com
Old 10-16-2009, 07:20 PM   #1 (permalink)
i have a 2003 f350 that my right front marker light has to be tapped to come on. How do I access the bulb and change it? It looks as if I have to pull the headlight!!! How might I attack this. thanks so much!!!!!
bambam911 is offline
Old 10-16-2009, 07:35 PM   #2 (permalink)
Texascadillac42's Avatar
My Photos: (10)
There are 2 screws at the bottom of the parking light assembly. You have to look hard to see them. Pull both of those screws and pull out firmly. The upper/outer part of the assembly has a line up pin that "pops" into place, this will require a firm pull to release it.
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline
Old 10-16-2009, 08:17 PM   #3 (permalink)
marker lights
thanks so much, found them and had success !!!!!!!!!!!!!
Old 10-16-2009, 08:27 PM   #4 (permalink)
My Photos: (10)
No problem.
