How to clean up rusted tire chains? - Page 2 - Diesel Forum - TheDieselStop.com
Old 01-06-2006, 01:02 PM   #16 (permalink)
Re: How to clean up rusted tire chains?
I second the Muriatic acid post. Mix it in a 5 gal bucket and immerse the chains in it for a short while. Check periodically. Thoroughly rinse and oil when done. It will kill grass, so be careful where you rinse them. Cheap and quick. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator replacement, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors and replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting replaced 10/19/14; Dummy Plugs replaced 11/8/14; Turbo rebuilt 11/29/14; cold side plastic CAC tube and boots replaced with metal tube 1/24/15.
Ford06 is offline   Reply With Quote Quick reply to this message
Old 01-06-2006, 01:14 PM   #17 (permalink)
Kanman's Avatar
Just take the damn things for a drag behind your pickup. run em down a sandy dirt road, or through a field. Forget soaking and spraying and and and lol. You drag em for 5-10 minutes and theyll be shiny new looking.
Kanman is offline   Reply With Quote Quick reply to this message
Old 01-06-2006, 04:56 PM   #18 (permalink)
5# of Citric Acid...WOW...I just paid $17.50 for 1# and had to have Kroger Pharmacy order it for me so I could clean my under the bar ice maker.
Soooo...since I live in Texas and you live in Louisiana...can you tell me where I might be able to buy Citric acid just a bit cheaper than $17.50 per pound? [img]/ubbthreads/images/graemlins/grin.gif[/img]
Rick Kimbrell
2006 350 XLT CC 6.0 SRW FX4 (no-ESOF) Automatic Trans, White over Arizona Beige, Cloth Captains Chairs, 3.73 LS, ABS, Clearance lights, Nasta polished stainless nerf bars, leveling kit, EGR fender flares
RickK is offline   Reply With Quote Quick reply to this message
Old 01-06-2006, 05:07 PM   #19 (permalink)
JimTJr's Avatar
My Photos: (20)
I dont know about citric acid,,the muratic acid it not that expensive I dont think,, Used for cleaning concrete drives and such...
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline   Reply With Quote Quick reply to this message
Old 01-06-2006, 09:42 PM   #20 (permalink)
[/ QUOTE ]Its used in pools too. So go to the pool section of the Walmart or a pool supply place and they will probably have the best deal on it. It comes in gallon jugs just like milk jugs
Mike1000000 is offline   Reply With Quote Quick reply to this message
Old 01-06-2006, 10:17 PM   #21 (permalink)
Not trying to do a thread jack here getting off the tire chain subject and onto citric or muratic acid subject...
I wish I could find something cheaper to clean my icemaker with but there is a warning about using muratic acid in it. Citric acid is the cheapest approved item I have found. But again, $17.50 per pound is not all that cheap.
Rick Kimbrell
Old 01-06-2006, 11:05 PM   #22 (permalink)
Whats wrong with White Vinegar? Thats what they use to clean coffee makers with.
Ford_Forgotton is offline   Reply With Quote Quick reply to this message
Old 01-07-2006, 12:35 AM   #23 (permalink)
Only thing I could think of is trying to get the scent out of the ice maker machine after running it for a couple of hours with it in there. Not sure how long it would take and doubt you would want to use the first day or so ice production. I clean the ice maker just about every month but only use citric acid every 9-12 months to clean the lime deposit from the machine. So the cost of the citric acid does not mount up that much over the course of time. However, I would probably do the citric acid treatment much more often if it were not as expensive. Basically I clean it pretty much according to the schedule that came with the ice maker.
Rick Kimbrell
Old 01-07-2006, 11:43 AM   #24 (permalink)
My Photos: (6)
Wow! I need to get out of industrial cleaning chemicals and into citric acid repackaging!!!! You don't want to know what I pay for Citric Acid in 50# bags... and I'm not even buying in volume!
I get to Houston from time to time... will do so in the next month. Drop me a line if you want me to bring you a few pounds.
As for HCl, I do a lot of work on stainless steel so I don't use HCl. The chlorides really screw up stainless steel. Also, HCl doesn't know when to quit. Citric is slower and really only goes for the rust, not the base metal.
OK... I admit it... real reason... I'm a safety sissy. I really, really, really hate corrosive chemicals. From HCl Acid to Castrol's Super Clean degreaser, I don't like extreme pH ranges. I partially neutralize my Citric to 3.5pH making it essentially non-reactive to the base metal but great on rust. And, it only stings if I have an open cut on my hands.
Yeah, I'm one of those guys who wears safety glasses in my own shop. I even have an eye wash station. I admit it.
Todd T
ToddT is offline   Reply With Quote Quick reply to this message
Old 01-07-2006, 02:00 PM   #25 (permalink)
Is their a beach near?If so put em on and go for a run.
99 f250 PSD stock as possible ok just a fumoto,and bilsteins
honeeagle is offline   Reply With Quote Quick reply to this message
Old 01-11-2006, 04:42 PM   #26 (permalink)
Kanman's Avatar
Todd T
I hauled a load of Citric Acid powder way back when. They came in these huge 500 lbs bags. Took them to Vicks where they make the Vitamin C Orange Drops. Apparently the citric acid doesnt come from oranges, it came from potatos [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Old 01-12-2006, 09:50 AM   #27 (permalink)
What he said. 5 minutes in the dirt, no harm done, no money wasted.
Tinscout is offline   Reply With Quote Quick reply to this message
Old 01-12-2006, 10:24 AM   #28 (permalink)
Here is my favorite method. Only used it once on a small part, but should work great for your chains.
Rust Removal
...danny
2001 'X' 7.3l PSD 4x4 Limited
Oxford White / Medium Parchment
K&N Air filter, Husky Floor Liners
20' H&H Speedloader MX Tiltbed Trailer
Bilstein shocks(BE5-6208 front, BE56209 rear) $259.80 to my door.
AllAboutJeeps is offline   Reply With Quote Quick reply to this message
Old 01-12-2006, 01:21 PM   #29 (permalink)
I use a cement mixer with a few shovels of ABC and let run for a few hours. Works great. Just do one at a time to minimize the tangle.
Or, put them on and drive in the sand.
2007 F350 White King Ranch Crew Cab 4x4
7" EDGE 4 Link Suspension, Fox Remote Reservoir Racing Shocks all the way around with Duals up Front, and Dual Steering Stabilizer. 37" Toyo MT's on 20" wheels.
Fully polished MBRP T304 turbo back exhaust finshed off with a 6" x 18" tip from ITP Diesel...Thanks Dennis!
Future mods, DePricol White Faced Gauges and a 24 volt inverter and power supply mounted in the bed,
NFA_Fun is offline   Reply With Quote Quick reply to this message
Old 01-13-2006, 05:28 PM   #30 (permalink)
MarvinVR's Avatar
My Photos: (14)
You know guys, I was expecting to get a lot of smart*** ribbing over this but there is some great info here and not for just chains. Thanks for some great advice.
2001 F-350 Lariat,CC,LB,SRW,4X4,Auto,7.3,2"lift,KYBs, 3.73, steel oil x-over, aFe Stage II Pro 7, AirCond mod, Fumoto, DP 60,80,100. AIH Delete, hi-lite/fog-lite on mod. CNC HPOP hoses. 360 degree illumination six light LED system for backup, fog and sides. Dead bird in grill. Part of finger in new ball joint nut. (really!)
MarvinVR is offline   Reply With Quote Quick reply to this message
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
