How to disable the seat belt reminder? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 11-08-2007, 02:07 PM Thread Starter
How do you disable the seat belt reminder?
I have the cord under the seat unplugged and it still dings away
2001 F350, 4x4, CC, LB, AIS
rymartin is offline
post #2 of 5 (permalink) Old 11-08-2007, 07:39 PM
Re: How to disable the seat belt reminder?
There are instructions in the owners manual. It involves about 6 steps, usually takes 2 tries, but it's not difficult.
'01 X 7.3 to tow my racecar...
AIS w/ sleeve
SRP 1.1
4" MBRP
FPR shim
TransGo shift kit (BTS coming soon)
Hellwig rear bar
DP Tuner-80E, Hi Idle, 60 tow
EGT, Trans temp, boost gauges,
...drags my 24' Shadow GT around like it's not even there
'91 Spec Miata
All vehicles full of BG Synthetic Fluids
fastersteve is offline
post #3 of 5 (permalink) Old 11-08-2007, 09:37 PM
Or you can just unplug the plug under the drivers seat. Took me all of 3 seconds.
There are two plugs, unplug one and if your power seat doesn't work, replug that plug in and unplug the other plug.
New:
2002 F-350 7.3l Crew Cab 7.3l 4r100, 185k, LB, SRW, ARE cap, 05 front end conversion, 05 dash conversion, high torque starter
To be installed: Veggiestroke V3 system, coolant filter, exterior transmission filter, heater core bypass, 3" hanger drop lift, dual front shocks, 35" nitto mud grapplers on 20" Diamo 17k rims, F650 auto lower dash panel
Old:
2002 F-350 7.3L Crew Cab, 245k, LB, SRW, DR 4.5" Hanger Drop Lift, Dual-Front Bilstein 5100 shocks, New Trac Bar, 20" Diamo 17k wheels wrapped with 35" Nitto Mud Grapplers, Veggiestroke V3 system, Leer cap (never going with Leer again)
no_regrets is offline
post #4 of 5 (permalink) Old 11-08-2007, 10:10 PM
I unplugged mine as No_Regrets says above.
I'm satisfied
2006, F-350, 6.0, 4x4, Lariat, crew cab, long bed with Leer 180 shell
MagnaFlow 4" turbo back exhaust system
DC Power Engineering 190 amp alternator
Firestone 2400 Ride-Rite air bags
Ranch Hand Legend grill guard
Isspro four gauge pillar set
HID Bi-Xenon headlights
HFCM water drain plug
Fumoto oil drain valve
Accufab intake elbow
Ctek batteries tender
DFuser coolant filter
Rotella Ultra ELC
Blue Spring mod
Bilstein stabilizer
ScanGauge II
Up-idle mod
Zoodad
ARCHOIL (AR9100, AR6200) & PRI-D & PRI-G Dealer
johnfjensen is offline
post #5 of 5 (permalink) Old 11-09-2007, 04:08 AM
This is straight from the owners manual, starting on page 103....
<u>Deactivating/activating the BeltMinder feature</u>
Read steps 1 - 5 thoroughly before proceeding with the deactivation/activation programming procedure.
The BeltMinder feature can be deactivated/activated by performing the following procedure:
Before following the procedure, make sure that:
• the parking brake is set
• the gearshift is in P (Park) (automatic transmission)
• the ignition switch is in the OFF position
• all vehicle doors are closed
• the driver’s safety belt is unbuckled
• the parklamps/headlamps are in OFF position
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1 minute)
• Step 3 must be completed within 60 seconds after the safety belt warning light turns off.
3. Buckle then unbuckle the safety belt 9 times, ending with the safety belt in the unbuckled state.
• After step 3 is complete, the safety belt warning light will be turned on for 3 seconds.
• If step 4 does not occur within 10 seconds at the end of step 3, Beltminder will automatically exit programming mode without
changing its enable status.
4. Within 10 seconds of the light turning on, buckle then unbuckle the safety belt.
• This will disable the BeltMinder feature if it is currently enabled. As confirmation, the safety belt warning light will flash 4 times per second for 3 seconds.
• This will enable the BeltMinder feature if it is currently disabled. As confirmation, the safety belt warning light will flash 4 times per second for 3 seconds, followed by 3 seconds with the light off, then followed by the safety belt warning light flashing 4 times per second for 3 seconds again.
5. After receiving confirmation, the deactivation/activation procedure is complete.
LittleBigRig is offline
