How do you change the dually fender clearance lights? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 03-15-2005, 07:01 AM Thread Starter
Surely someone here has done this before. Do they pry off of the fender or do you have to get behind the shroud in the fender? Any help is appreciated.
99.5 F-350 XLT, CC, DRW, 4x4, 7.3l, 4.10 LS
Travis350 is offline
post #2 of 4 (permalink) Old 03-15-2005, 08:32 AM
Re: How do you change the dually fender clearance lights?
Travis, I think you have to get to them from inside the shroud, and the whole assembly comes out, and you replace with a new one.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
post #3 of 4 (permalink) Old 03-15-2005, 08:58 AM
Travis,
Pop the Plastic rivits loose that hold the shroud on, reach behind, grab the wire end of the fixture, twist it slightly... the socket and bulb will come out. change The bulb, twist it back in, push the plastic rivits back in... Done Deal.
JOE
2K, F-350, XLT, XCAB, 2WD, DRW, 6 Spd, 3.73LS, 4 Pod pillar mnt, EGT, Boost, Trans/Engine temp, Fuel press. guages, Quadzilla 50/75/120,ES AIS w/fender mod, Shimmed FPR, Dahl pre-pump filter, HX Mod, Racor (Mod'd) CCV, Premo oil Refiner, W/Wheel with both TAGs, Banks W/gate actuator, DT466 CPS, 6.0 Intercooler, Banks I/C tubes & DPP boots, 25psi BPRV, Full 4" exhst, AeroTurbine w/exhaust guide, MagnaFlow, Intake Heater Delete, Heater core bypass, 203* Thermo, Coolant Fltr., "Hutch" Tank & Fuel system Mods,fill pipe fix, Mag-Hytec Dif cvr, Fumoto, Bilstiens, SafeTplus Steering Dampner, Centramatic's, Ride Rites, SilverStars, Clear APC Head/Tail/Corner & all Marker lights, 2 850cca Optima's, Ultra Boards, Burlwood Dash, XM radio, Billit Grill (Black). TTMs/C-beters. Pull a 32 ft Montana FW. 102K
BIG JOE is offline
post #4 of 4 (permalink) Old 03-15-2005, 03:19 PM Thread Starter
I appreciate the help guys. I'll switch it out tonight.
Travis
