How do you replace driver side headlight? - Diesel Forum - TheDieselStop.com
Old 06-12-2006, 09:06 PM   #1 (permalink)
Strange issue. The passenger side headlight went out. I took it out, then the passenger headlight didn't work. I needed at least one light so I put the passenger light back in and now the passenger side works and the driver side is not working. [img]/ubbthreads/images/graemlins/confused.gif[/img]
I can only get my hand in far enough to turn the plastic gizmo on the driver side. The battery compartment is in the way. Is there a way to take the whole glass part off? How can I get the bulb out? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Thanks!
2002 F350 PSD 7.3 4X4 Crew Cab
2003 26' J&L Cargo Express Express Living Toy Hauler
2006 KXF450 / 2007 KX65
TripleClamp is offline
Old 06-12-2006, 09:51 PM   #2 (permalink)
Maintain's Avatar
Re: How do you replace driver side headlight?
You can remove the airbox, and the battery. It will only take you a few minutes and then you have ez access to the back of the light. While you have the airbox out you might as well install this! [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2001 F250 CC/SB Platinum
11.62 @ 115.79
SWAMPED
Maintain is offline
Old 06-13-2006, 08:34 AM   #3 (permalink)
Pictures worth a thousand words! Thanks!
Old 06-13-2006, 12:31 PM   #4 (permalink)
if the same as an 01 should be 2 metal clips in the top rear of the light. they are bent at a 90 degree angel so you can grab them and pull up about a third inch. the light should fall to the ground, hopefully being stopped by the wires so get ready to catch it.
All things in Moderation accept ACCELERATION!!!!
Zip ties... the duct tape of the new milenia!
truckosaurus
2001 F250 Crew, 25,000+ miles, PSD, 4X2, ProComp 6" lift, Short Bed, SCMT, Tymar set up, BTM, ISSPRO Pyro, boost, and Trans Gauges, in tank mods and harpooned, 28" air horn w/ on board air and tank also full set of train horns! 6 gallons of 150 PSI air. Prodigy, Draw tite Signature series 18K 5'r hitch. TTM
2005 wildcat 29RLBS 5'r, parallel EU2000i's
2003 Explorer, EddieBower, V8 4X4
2003 Explorer XLT, V8 4X4
2002 XR50
2001 PW50
taxgod4u is offline
