How to engage the 4 wheel drive - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 08-31-2010, 08:49 PM Thread Starter
How do you engage the 4 wheel drive
juve0011 is offline
post #2 of 11 (permalink) Old 08-31-2010, 09:10 PM
Manual 4x4 auto 4x4, high low?
06 F-250 x/c 4X4 sb 17" alloy wheels. Tri-fold tonneau cover, weathertech vent visor,Ford floormats and splash guards. HarleyD headlights, Duplicolor bedliner coated bumpers, 08 rear bumper and taillights, herculiner rocker panels, XM radio, bosch wipers, Recon smoked cab lights, Edge Insight w/EGT probe, winter front.
06/10 ARP studs, turbo back silverline, new head gaskets, new oil cooler, upgraded turbo drain, fuel pressure reg upgrade, coolant filter, high idle mod, harpoon mod, pre-pump spin on fuel filter,ELC coolant, 6.4 banjo bolts, CCV reroute.
Truck weight empty fueled up, 4440 Front, 3040 rear, 7480 gross. Hex VXCF4,
SCT w/customs tunes from Vivian at Quick Tricks and Matt @ gearhead
worldwide73 is offline
post #3 of 11 (permalink) Old 09-01-2010, 07:51 AM Thread Starter
Low auto
juve0011 is offline
post #4 of 11 (permalink) Old 09-01-2010, 08:48 AM
truck needs to be in neutral.
post #5 of 11 (permalink) Old 09-01-2010, 08:59 AM Thread Starter
And just turn the knob to 4x4 low
juve0011 is offline
post #6 of 11 (permalink) Old 09-01-2010, 06:54 PM
yes. just put it in nuetral them turn the knob to 4x4 low.
MAS1866 is offline
post #7 of 11 (permalink) Old 09-02-2010, 09:13 AM
In neutral, and foot on the brake works for me.
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
SOLD:2011 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Sterling Gray Metallic
SOLD:2005 F350 XLT 4x4 FX4 SRW SC SB 6.0 PSD/TS Med. Wedgewood Blue, Dual Alternators, Tow Command, Bypass Coolant filtration.
djousma is offline
post #8 of 11 (permalink) Old 09-03-2010, 04:57 PM
dijoeboss's Avatar
yeah,foots gotta be on the brake also,have to take out the same way,truck stopped,foot on brake,gear selector in nuetral....to get it into and out of 4X4 low.....
dijoeboss is offline
post #9 of 11 (permalink) Old 09-03-2010, 05:09 PM
JimmyDee's Avatar
My Photos: (24)
This is what it takes with mine for low range.
Jim
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod;
, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in
AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is offline
post #10 of 11 (permalink) Old 09-06-2010, 04:52 PM
Well, I usually just lock in the hubs and pull the transfer lever into 4Hi or 4Lo. Unless I'm in my Toyota with ADD, then I forego the locking of the hubs.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
post #11 of 11 (permalink) Old 09-06-2010, 06:10 PM
Make sure your stopped when doing this. You can shift in and out of 4WD High while you are moving and when I do that I usually don't do it if I am going more than 30mph and never on pavement.
2OOO F-250 4WD Crew Cab, 267,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator, H2O Pump. AIS Severe Duty Filter, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Mesa, Arizona
PRDATR is offline
