How many miles left with low-fuel light on? - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 05-20-2010, 01:37 PM Thread Starter
turbo_diesel's Avatar
Exclamation How many miles left with low-fuel light on?
This is the stupid question of the day but i need to know. I have a 04' F350 power stroke turbo diesel. How many miles do i have till empty when the check engine light comes on?
turbo_diesel is offline
post #2 of 14 (permalink) Old 05-20-2010, 05:34 PM
Don't know..........depends on when the check engine light comes on.
Did you mean the "low fuel" indicator light?
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
post #3 of 14 (permalink) Old 05-20-2010, 09:42 PM
My Photos: (19)
assuming you are talking about the short bed truck in the pic, it makes a difference short bed to long bed. I'm fairly certain you have the smaller tank which is 32 gallon tank, and if it comes on at 1/8th of a tank then that is about 4 gallons. Assuming you are getting about 15mpg then you have about 60 miles. That also assumes your gauge is reading very accurate. Most of them don't.
IF you mean the check engine light, the only thing that is going to empty out is your wallet. Then I'd say anywhere from 10 miles to 400 miles.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
post #4 of 14 (permalink) Old 05-29-2010, 10:12 AM Thread Starter
Yeah i meant low fuel light. thanks guys
post #5 of 14 (permalink) Old 05-29-2010, 01:13 PM
SmokeyWren's Avatar
My Photos: (45)
How many miles do i have till empty when the (low fuel) light comes on?
It probably varies. Only once in the last 11 years did I care. I was heading home from a long trip and wanted to make it to my home truckstop before I fueled up, so I gambled. The low fuel light came on with about 30 miles to go. I made it to the truckstop, but I'm sure I came in on fumes. That fillup my 38 gallon tank held 42.8 gallons when filled to the cap with liquid diesel. I averaged 13.295 MPG on that tankfull, so I probably had a smidgen more than 2 gallons left when the low-fuel light came on.
SmokeyWren is offline
post #6 of 14 (permalink) Old 05-29-2010, 01:43 PM
My Photos: (35)
As it has been said, each truck or car is different.
There are some that when the needle is at the E there is enough to get to the next station, while there are others that when it gets to the E that is it, no more fuel...... and one is along the side of the road.
I know that I have pushed that line very few times, as I do not wish to find out just how close I can push it.
2000 E350 7.3PSD, Hellwig Stablizer bar, 1.5"spacers from old Correct track OR,140 Lightforce with covers, 5x7 LED's From Truck-lite, extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E, My Photos
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
Alaskapsdvan is offline
post #7 of 14 (permalink) Old 05-30-2010, 10:09 AM
2000Ford250's Avatar
my last truck, a 1 ton with a 460, had two tanks,
one would read full, untill the truck bucked and lurched,
then the needle would drop to read empty,,,
the other tank, would read full, and suddenly go to half empty, then read correctly to empty,
and then i had about a mile or so after the light went on,
I HATED THAT 6MPG TRUCK, on the alaskan highway,
the truck loved the canadian gas stations,
Hence me buying the sweet diesel i have now,,
100 gal in the back, and 30 in the truck, 19MPG
washington to Tok, it diesnt like those canadian stations,
2000 F-250 XLT ,6spd, Short,bed, (when I bought it, 134,000)
6637 DIY Air Filter, EV2 Pyro,Boost Gauge,Muffler-Delete (came that way),Turbo Rebuild with Billet RiffRaff Wheel,(Balanced)
Turbo and Spider, Painted Red,Intercooler-Tubes,Painted,RED,NON-EBPV Pedestal,Painted,RED,EBPV valve delete Mod
TurboMaster WasteGate controller
DRK Blue CPS, "Black" one in the Glovebox
1-9000 longmile trip
now sportin 175,000
24ft alpenlite,sliding hitch, for those days when civilization isnt so civilized
2000Ford250 is offline
post #8 of 14 (permalink) Old 06-04-2010, 02:46 AM
It depends on how much traffic there is and if it is snowing or raining out.
2003 7.3 F250 SD SRW Auto DIY intake 285/70 1.5" Leveling Kit TS Performance 75 HP Chip
TTBadDog is offline
post #9 of 14 (permalink) Old 06-04-2010, 08:47 AM
RIStroker2000's Avatar
Send a message via AIM to RIStroker2000
I think it would depend on how 'clean' the inside of you tanks is (which you have no idea unless you pull it ) if somehow you have debree or sludge etc.. then you could read say 50 miles left when you really dotn cause of blockage... i was on e one time, 50 miles, got close to the station it read 45... then the turn into the station with its bumpy, risen 'platform' (higher than the road) the electronic gauge dropped to 7 and i litterally 'bucked' into place.. filled up was fine
generally if it tells you 100, its really only 60ish, if it says 60, you need gas NOW.. especially with these trucks
2000 7.3 Extended Cab Long Bed Lariat...
nothing crazy, it carries alot of weight, it tows alot.. has all the 'usual' upgrades plus some..
she breaths well, has extra air and fuel
RIStroker2000 is offline
post #10 of 14 (permalink) Old 06-04-2010, 10:25 AM
Or how far it is to the next station.
post #11 of 14 (permalink) Old 06-04-2010, 10:58 AM
bugman's Avatar
My Photos: (12)
What you need to do is find out exactly how much your fuel tank holds. Then figure out just what your mileage is with what ever you haul in your truck. Then drive around until the light comes on and then hit a fuel station and see how much fuel you can put into the tank. Subtract this amount from what your tank holds and multiply the results by what your mpg is. Then you will have an idea of how far you can go.
bugman is offline
post #12 of 14 (permalink) Old 06-04-2010, 01:55 PM
doczenith1's Avatar
My Photos: (11)
I took a different approach because I have a gasser and running out of fuel is no big deal as long as you have a full gas can nearby. My results are for a gasser but should be similar.
I loaded a 5 gallon gas can (with 5 gal of gas) in the back of the truck and headed out for a weekend trip. On my way home I purposely ran out of gas. After pouring the 5 gallons of gas into my tank I drove to the nearest gas station which was only two miles away, thus not using much gas after running out. I made sure to fill the 5 gallon gas can to the same level as it was before filling my truck on the side of the road. Here are the results.
8794 - low fuel light comes on, overhead display (OHD) says 27 miles to empty.
8813 - OHD says 10 miles to empty.
8832 - OHD says 0 miles to empty. (wow 10 miles = 19 miles…)
8866 - ran out of gas, OHD says 16.1 mpg. (70 mph…must have been a tailwind!!)
Now, I reset the OHD when the low fuel light came on, to get the correct gas mileage for the last few gallons. This will be used to calculate the number of gallons left in the tank when the low fuel light comes on. You will notice the 'OHD - miles to empty' gets a bit confused when the fuel level gets low. From my calculations, there is about 4.5 gallons in the tank when the low fuel light comes on based on 16 mpg. I've found that the OHD runs about .5 mpg high, so the 4.5 gallons is conservative.
It took 29.3 gallons to fill the gas can and the truck. This is to the point where the pump automatically shut off. The most I've trickled in after the pump shut off is about 4 gallons.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's
SOLD
2003 Mustang SVT Cobra, black convertible. - 6/2007 - 9/2013
SOLD: 2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
post #13 of 14 (permalink) Old 06-04-2010, 10:36 PM
468LC's Avatar
I'd be willing to bet in my 99 that I could go unloaded about 80-90 miles from the time the light very first comes on.
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 100k miles.
Wix coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT. Sinister EGR delete, EGR cooler delete, up pipe. Looney Tune via SCT X4. S&B Intake.
Mag-Hytec transmission pan, 08 diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
2012 Heartland 5th wheel. 36' @ 12k pounds.
468LC is offline
post #14 of 14 (permalink) Old 06-05-2010, 06:57 AM
nitrogen's Avatar
just keep in mind that the lower you run the fuel, the more likely your fuel pump is to momentarily suck air due to sloshing. this leads to low fuel pressure, which leads to a real expensive set of new injectors. compare the $ for a set of injectors to the $ to stop sooner and put in at least some fuel.
nitrogen is offline
