how much did you pay? - Diesel Forum - TheDieselStop.com
Old 03-31-2009, 10:08 PM   #1 (permalink)
I had brake problem while on vacation. front pads gone. rotors need turned and 1 caliper is frozen.
How much do you think a repair like this should cost?
traildog
Rear main engine seal replaced @ 13,500 miles. Engine pulled for Bed Plate Leak @ 28,500 miles, hasn't leaked a day since (57K now)
2005 F350, 4X4, FX4, DRW, CC, Lariat PKG, Tow Boss, bone stock.
60K oil cooler, egr cooler, degas bottle, hoses.
traildog is offline
Old 03-31-2009, 10:31 PM   #2 (permalink)
I just worked on these in the last three weeks. I bought the parts at O'Rielly's. I may not have the prices exact but close. Pads $37. Caliper $65 with a $50 core charge. I priced rotors $75 but found a shop that turned mine for only $5. (yes only five dollars). O'reilly's would not turn my rotor. They told me the specs on what they could turn and they were only 10 thousanths difference from what the new one was. In other words, because my rotor measured 13 thousanths wear and not less than 10 thosanths, mine was out of their spec range to turn. Good luck with your project.
Tim
2000 F350, 4x4, crew cab, Lariat, short bed, dually, auto tranny, Edge Evolution Programmer
SOLD 1996 F250,4x4,ext.cab,XLT,automatic,open air intake filter, dead cat,285/75/16s on stock aluminum wheels
SOLD 1990,F250,4x4,ext. cab,XLT,223,000m,7.3 stock except for home made ram air to K&N filter,2 1/2 dual exhaust, pump turned up one flat, 8' western snow plow
tlsdiesel is offline
Old 03-31-2009, 10:58 PM   #3 (permalink)
Just had my front brakes done, Parts were $47.00 for Pads, Rotors were about 80 dollars each and Calipers were $65.00 before core charge. Plus $200 for labor (including doing an Oil change).
bobk is offline
