How much does a 2000 1 ton dually weigh? - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 11-08-2007, 06:56 PM Thread Starter
I have a quick question I hope someone can help me with , my buddy has his 1ton f350,7.3, single cab with a steel flatbed and tool boxes he needs towed. All I have is a 18 ft car hauler trailer with 2, 3500 lb axles.Will my trailer handle his beast?
2000 Ford XLT,SC,7.3,auto,SB.4 inch straight pipe,mod airbox,trans gauge,
1984 Eagle Model 10,6V92 turbo,740 allison,A 2 stroker!
1990 Superduty (f-450) 2wd, 7.3, 5spd, dana 80, 5
5.13's
2002 F350, CC, dually ,auto,51k miles. stock
texasjack308 is offline
post #2 of 19 (permalink) Old 11-08-2007, 07:42 PM
lone_star_dsl's Avatar
Re: How much does a 2000 1 ton dually weigh?
Maybe if he runs it almost out of fuel. My truck weighs in at about 8,400. Thats with the aux tank empty.
2016 RAM 3500 Big Horn, CC LB, DRW, 6.7 CTD, 4wd, Aisin trans
Gone but not forgotten...
2002 F-350 SRW
Lariat, Crew Cab, Long Bed
4X4, Auto Trans, Tymar Intake
Wicked Wheel, Zoodad Mod
DP Tuner - 60E, 80E, 40T, 80T, Decel
05+ Harley Headlights
6" Upper and Lower Windshield Brows
ISSPRO Gauges, Edge Insight CTS
Sold at 206,000 miles
lone_star_dsl is offline
post #3 of 19 (permalink) Old 11-08-2007, 08:20 PM
Mine weighs in at 8800 but I have extra stuff on it. I think it might be a bit much for the trailer.
Early 99 Ford F-350 4X4 Extended Cab Dually, 4 in lift, 6spd, dual 5in stacks,ts 6 stage, zoodad, ccv, tymar,
240,000 miles and counting
1993 Ford F-350, 4X4, Fuel Injected 460, MUD TRUCK, 40in super swampers, Dana 60 Front, Dana 70 Rear, 10in home made lift.
1982 Mustang 302 HO
HOURS TO BUILD, SECONDS TO BREAK
mflores is offline
post #4 of 19 (permalink) Old 11-08-2007, 08:46 PM
Texascadillac42's Avatar
My Photos: (10)
Im around 8200 lbs with half a tank of fuel
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline
post #5 of 19 (permalink) Old 11-09-2007, 12:20 AM
I'm sure the steel flat bed and tool boxes will push the weight well over 9k.
Check your trailer tire load rating. If the tires will hold it and the haul distance is short, you will probably be OK. In reality, get a bigger trailer.
good luck
05 F350 Lariet SC 4x4 6.0/auto lgbox Toyo AT's, bilsteins, on board air with airbags & air horns
gmoore is offline
post #6 of 19 (permalink) Old 11-09-2007, 08:08 AM
I would say that your trailer is a light for the load.
as stated my DRW, CC is over 8K.
1992 E350 7.3 IDI, 3.73 club van - 160K
1998 Quad cab 2500 12V Cummins, 4x4,auto, all stock with 145K miles
2000 F350,DRW converted to SRW with Vision 19.5" wheels,4x4,6 speed,Lariat,Napa 6642 airfilter,Edge Juice w/Attitude,Cody Cushon gooseneck, 175K, Prodigy, 3.73 gears
2002 TDI Jetta Manual 200K
2002 TDI Jetta Manual 230K
2003 TDI Jetta Maual 90K
1999 Polaris Diesel Quad
2004 Kubota BX 1500 599cc diesel
(yah I like the old mechanical diesels
Westro is offline
post #7 of 19 (permalink) Old 11-09-2007, 10:16 AM
My old early '99 CC dually 2X4 was 8,900 at the landfill scales with 3/4 fuel and tool box in the bed. I don't think your trailer is up to the task.
2005 F-250 XLT 4X4 V-10
2006 Wildcat 31QBH Fifth Wheel
imsailor is offline
post #8 of 19 (permalink) Old 11-09-2007, 03:18 PM
My '01 with flatbed (supercab) is just under 9Klbs.
DirtFarmer is offline
post #9 of 19 (permalink) Old 11-09-2007, 04:53 PM
My Photos: (6)
Mines about 8500lbs... is that trailer wide enough? mine will not fit on my trailer.
2001 F350 Dually, Crew Cab, 6x6, Lariat, 7.3 PSD, Auto, 4.10's, Camper Package
6" Lift [4.5" DR lift, X springs upfront, 6" DR Rear blocks] Dual front Bilsteins 5100,
37x12.50x17 Pro Comp Xtreme AT's, Eagle 058's 17x8 front 17x6 rear,
custom 17" steel inners by Rickson, 3" rear dually spacers, BTS trans
DP Tuner F6 Chip (No Start, Stock, Hi Idle, 40T, 60T, 80E, 120R)
4" SS MBRP Cool Duals, Banks 1.0 Exhaust Housing, Banks Big Head, AIS Intake w/ Fender Cutout
DiPricol Optix Boost, Pyro, Full Sweep Trans Temp, DP Tuner Gauge Switcher
DB high-torque starter, Power Slot Cryo rotors, Hawk Pads, SS lines
More to come...
2000 F250 7.3 PSD 35" MT's, MBRP Cool Duals, AIS Intake w/ Fender Cutout, DiPricol Optix Boost, Pyro, Full Sweep Trans Temp
2002 F450 7.3 PSD (30k) 12ft Dump... AIS Intake w/ Fender Cutout
TalontedTSi is offline
post #10 of 19 (permalink) Old 11-10-2007, 03:45 AM
I'm really surprised at everybody's weights. I weighed in at 8300# with me in it, a full tank of fuel, and all the extra for the lift kit and tires.
Danny Om
01 SC PSD Dually (build date 08-00 w/ PMRs), 8" Edge, dual F&R Doetsch aluminum shocks w/ resevoirs, 37" SSR on all 6 tires, 2" (hub & wheel centric) wheel adapters by Fearless Fred Goeske, Fabtech racing track bars.
APC Projectors (HID 10k), clear corners, clear cab lights, clear dually side markers, Amp-Research retractable side-steps, power rear-slider, Snug-Top canopy, billet grill, and chrome truck nutz!
Fully built motor w/ B-codes, GT42R, and Terminator w/ remote IPR HPOS.
Auto Enginuity Pro-Bundle equipped if you need assistance locally.
duallyduty is offline
post #11 of 19 (permalink) Old 11-10-2007, 12:32 PM
My Photos: (9)
My '02 weighed 7900 with a 1/4 tank of fuel leaving the dump a couple of weeks ago.
My neighbor has a steel flatbed on his Dodge- it weighs about a thousand pounds more than his factory bed did. Sounds like you need a bigger trailer.
2001 F-350 XLT, DRW 4x4 6 speed
Foxx is offline
post #12 of 19 (permalink) Old 11-10-2007, 02:55 PM
If all these F250/350ss weigh over 8000lbs, how can they have a decent payload if the GVWRof an F250 is as low as 9000lbs for a 4X4?
16' F250 CC 6.2
Ugly-Jeep-Truck is offline
post #13 of 19 (permalink) Old 11-10-2007, 07:33 PM
My Photos: (9)
My '02 has a GVWR of 11,500. Even weighing 8500 pounds, that leaves roughly 3,000 pounds, so long as I dont exceed the RAWR.
Where did you find an F-250 with a GVWR of 9,000?
Foxx is offline
post #14 of 19 (permalink) Old 11-10-2007, 08:06 PM
I'm looking right at the brochure, the F250 GVWR goes anywhere from 9000-1000 with a SRW 4X4..so in theory since an F250 weighs the same as an F350 (essentially the same truck), it seems to me that legally an F250 does not have that much of payload, if what all these guys are saying with them weighing well over 8000lbs.
16' F250 CC 6.2
post #15 of 19 (permalink) Old 11-10-2007, 10:28 PM
SmokeyWren's Avatar
My Photos: (45)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: wickedsprint</div><div class="ubbcode-body">If all these F250/350ss weigh over 8000lbs, how can they have a decent payload if the GVWRof an F250 is as low as 9000lbs for a 4X4? </div></div>
You misread something. The topic is about a "1 ton dually". So there are no F-250s listed above, and there are no F-350 SRWs listed above. All the F-350s with weights listed above are duallys (DRW). So the folks have been good about staying on topic. [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img] Until now. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
'99 - '00 F-350 DRW had a GVWR of 11,200
'01 - '04 F-350 DRW had a GVWR of 11,500
'05-up PSD CrewCab 4x4 DRW has a GVWR of 13,000 pounds.
Your argument is valid for an F-250, and especially for the '99-'04 F-250 with only 8,800 pounds GVWR. My '99.5 F-250 CrewCab 4x2 PSD weighed about 7,000 pounds when new and empty before any mods. But the "normal unloaded" weight is around 8,000 pounds, including toolbox full of tools and extra fluids, spray-in bedliner, floor jack, big bottle jack, full tank of diesel, torque wrench and lugnut sockets and other stuff behind the back seat, me and Sweetheart and puppydog. So my max unused payload available for trailer hitch weight is about 800 pounds without exceeding the GVWR of my tow vehicle. So needless to say, I'm usually overloaded by a few hundred pounds when towing the 5er. [img]/forums/images/%%GRAEMLIN_URL%%/blush.gif[/img]
SmokeyWren is offline
