Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 11-05-2009, 06:56 PM   #1 (permalink)
becxlt's Avatar
How much friction modifier
How much friction modifier should I be adding to a Dana 10.50 rear axle ?
The Motorcraft Additive comes in 4 fl oz bottles ..
The Ford owners manual also calls for SAE 90 W Gear oil for the front differential all I can seem to find is the 80 W-90 .. Would this work ?
becxlt is offline
Old 11-05-2009, 08:32 PM   #2 (permalink)
You need 2 bottles, it requires 8 oz.
Ljutic SS is offline
Old 11-05-2009, 11:24 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (42)
If you're in the right forum, then you don't have a Dana 10.5 rear axle. If your pickup has single rear wheels (SRW) you have a Ford-design rear axle with a 10.5" ring gear. If your pickup has dual rear wheels (DRW), then you have a Dana 80 design rear axle with a 11.25" ring gear.
As to how much friction modifier, you may need none, or one bottle, or at most two bottles - depending on which brand of diff lube you buy. Some brands of 75w140 synthetic gear lube say you don't need to add any friction modifier for your limited slip axle. Ford has conflicting requirements - in one place they say 4 ounces and in another place they say 8 ounces.
So first read the label (and the website) of the brand of diff lube you install. If it says you don't need friction modifier (Royal Purple, Amsoil, and maybe others), you probably don't. If you do need some, I'd pour in only 4 ounces (one bottle), then button it up, drive a coupla miles, then do some figure eights on a parking lot with high traction surface such as rough concrete. If you hear the LS clutches making a racket, then add another 2 ounces and test it again. You should never need more than 8 ounces.
You don't say the year or model of your truck, but if it's a Dana 60 front axle, the workshop manual now calls for:
Motorcraft 80W-90 Premium Rear Axle Lubricant XY-80W90-QL (US); CXY-80W90-1L (Canada) (Model 60/70 axles)
SAE 80W-90 Premium Rear Axle Lubricant
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; Ford Severe Duty Air Induction System (AIS); 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and Turbo Temp Monitor (TTM); Auxiliary Idle Controller (AIC); SP-Diesel exhaust brake and torque converter controller. Top Job front end replacement. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is online now
