Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 06-08-2006, 09:51 AM   #1 (permalink)
My Photos: (5)
How are my "warped" stock rotors unwarping themselves?
Maybe they aren't warped. Over the past 2 months, my brakes have gotten better. Two months ago I was afraid to hit the brake pedal. The truck would bounce like crazy. At this time of year, I use my dump trailer a lot and have noticed that my brakes are feeling less and less warped. There is still a small pulse, but NOTHING like i had 2 months ago. What do you think is actually happening?
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, DP Tuner F5 - no start, stock, 40t, 60t, 80e and 80t, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, currently 80,100 miles. truck Pictures
clydesdale is offline
Old 06-08-2006, 09:58 AM   #2 (permalink)
My Photos: (5)
Re: How are my "warped" stock rotors unwarping themselves?
Probably the caliper slide pins seized up, and now have possibly worked loose enough. Or maybe you got used to it?
Pocket is offline
Old 06-08-2006, 10:04 AM   #3 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
LOL. I have noted the same thing. My front rotors developed some disc thickness variation (DTV) shortly after driving the truck after a prolonged winter rest in my driveway (alternator and battery replacement). I had changed to PF Z-rated pads and had the rotors turned on the vehicle with a Pro-Lathe about 8 months before to deal with a DTV problem. It was back. Well within a few weeks of towing with a full horse trailer at max GCVW, the problem was slowly disappearing. I switched to the PF pads at FMTRVT's recommendation as they were more abrasive (higher µ ) and would "true" the rotors more than the OEM formulation. By the end of the summer no more pulsation. So I think your "warped rotors" can unwarp especially if braking with heavy loads and more abrasive aftermarket pads.
haul_n_horses2 is offline
Old 06-08-2006, 11:06 AM   #4 (permalink)
When I installed my ART Cryogenically-treated rotors, the installation instructions heavily emphasized a bedding-in procedure. The claim is that the procedure deposits a layer of pad material on the rotors that helps increase the friction. They say to re-do the procedure if the brakes exhibit any vibration.
It makes me wonder if the variations to this deposition layer are possible of exhibiting the same symptoms as warped rotors and thickness variation. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I couldn't help but to also wonder if the same procedure wouldn't have re-applied this layer to my OEM rotors, thereby eliminating a potentialy unnecessary expense. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
After I bought them and installed them. [img]/ubbthreads/images/graemlins/frown.gif[/img]
I really like the extra stopping power that I now have, but if I had known then what I think I know now . . . I would have tried the bedding-in procedure on my OEM stuff before dropping $400 on aftermarket pads and rotors. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
DarthSurplus is offline
Old 06-08-2006, 12:41 PM   #5 (permalink)
FMTRVT's Avatar
As Hauln' noted, the primary issue with brake pulsation is that the rotors are worn unevenly to the ratio of rotor wear during brake applications, to rotor wear when a pad is touching the rotor during normal driving (non-braking event). For people that do a lot of highway driving, the OE material's rotor abrasion during is not enough to keep the rotor trued, if the pads are touching the rotor and not sliding to a fully retracted position. It's not a case of the rotors "warping" from heat. This occurrence can be aggravated if the rotors are stress distorted from improper lug nut attachment during a tire change or rotation.
In Hauln's case, if I remember correctly, he had already changed out to the PF pads earlier. After parking the vehicle during the winter and having some rust build up on the rotor (my belief), the oxidation wore away and the pulsation subsided as well.
Same in you case. Some uneven wear on the rotor developed, and now that your using the vehicle more like it was designed for (commercial application) the brake-on wear rate is higher and the rotors are trued.
If the situation was as simple as material transfer, a person could cure the issue with some light sanding of the rotors surface with some 120 grit abrasive. But that occurs with organic formulation on much lighter weight cars.
This is not the total answer for other cases, as other issues such as tire balance, bearing condition, and a host of others can allow a high rotor runout under operating conditions, wearing the rotor unevenly. And if the rotors were stress distorted for a good wile and have seen some thermal history under that condition, they can become permanently distorted. And if a pulsation condition is not corrected quickly, a hard spot can form in the rotors surface (including with cyro'd rotors) that will never be corrected. I could go on .....
Jack
Pics & Instructions:
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 6 Disc Radio Speed Volume Mod . Look Around, Lotsa Stuff
Oil Study Spreadsheets
FMTRVT is offline
Old 06-08-2006, 12:48 PM   #6 (permalink)
My Photos: (5)
so, maybe i should hold off on installing my new cryo rotors and hawk pads? I could see where this goes and if it gets even better over the next month. I will grease the slide pins first though. Any other suggestions? And there is no way I just am getting used to it. Stuff in the center console was getting ready to jump out and now it is a slight annoying pulse.
Old 06-08-2006, 06:20 PM   #7 (permalink)
its weird mine are better too, mabye the warmer weather? i dont know either but mine are much smoother too.
2002 f350 crew cab short box 3inch tuff country level kit 315 toyo mudd terrains on 8 inch nitto rims afe stage11 intake with pre filter window tint leer canopy auto meter quages . 4 inch mbrp exhaust. superchips 1805 tuner. towinn our 2004 27 ts komfort tt.
http://community.webshots.com/user/rws444psd
rws444psd is offline
Old 06-09-2006, 06:20 AM   #8 (permalink)
My Photos: (17)
[/ QUOTE ] I have a pair of very pricey PF front rotors and complete set of PF pads sitting in storage because the problem corrected itself. LOL.
Old 06-09-2006, 07:52 AM   #9 (permalink)
Subman's Avatar
So what is the breakin(or correction)proceedure for brakes?
2002 F-250 S/C LB, Auto, VDH5, 3.73LS, My Truck
Complete fuel mods, coolent filter, Heater Cutout Valve, Walker BTM, Gauges(Pyro,Water,Trans), Jody's Econo tuned PCM, Turbo LifeSaver, AIS Severe Duty Filter Kit, Dahl filter and CCV Reroute to exhaust pics. CCV to exhaust since 4/27/03.
Subman is offline
Old 06-10-2006, 09:17 AM   #10 (permalink)
VS06SD's Avatar
Here is a site with instructions for bedding in new pads...
Bed in Procedure
06 F350 6.0 Lariet Crew Cab DRW FX4
06 F350 6.0 XL Reg Cab DRW 4X2
09 Eagle 314BHDS TT
94 Explorer XLT 4X4
VS06SD is offline
Old 06-10-2006, 05:07 PM   #11 (permalink)
My Photos: (17)
That procedure is very similar to what Jack (FMTRVT) told me to do with my PF Z-rated carbon-metallic pads and OEM rotors except it was not necessary to stop fast. The energy kinetic energy converted to thermal energy is the same regardless of how fast you decelerate.
Old 06-10-2006, 05:57 PM   #12 (permalink)
Subman's Avatar
THX!
Bed in Procedure
Subman is offline
Old 06-10-2006, 06:15 PM   #13 (permalink)
My Photos: (6)
Whalp, you got added weight (trailer). Likely the thickness variation of brake material bedded on the disk has evened out through higher pressure application of the pads. I've found a stand-on-the-brakes stop or two to temporarily smooth out pulsation....
Try this: Retorque all wheels to 150 ft lb in the recommended way. Do it again a few weeks down the road. Amazing! The stresses from varying torque on the bolts will create pulsation where there should be none - uniform recommended torque can work wonders.
Here's some reading, standard stuff for this board: <font color="blue">Warped Brake Myth Explained</font> [img]/ubbthreads/images/graemlins/smirk.gif[/img]
'04 Lariat 4X4 CC
CalWaterboy is offline
Old 06-12-2006, 09:54 AM   #14 (permalink)
My Photos: (17)
[/ QUOTE ] This thread is more informative than the Stoptech article.
Old 06-13-2006, 09:51 PM   #15 (permalink)
FMTRVT's Avatar
I would wait. And during that time, don't try to anticipate a brake application and slow down. Use the brakes a little more (application wise) and see if it wears true. It's worth a shot rather then replacing the hardware.
Jack
FMTRVT is offline
