How to remove the headliner in a crew cab - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 06-03-2011, 09:11 AM Thread Starter
Has anyone removed the entire headliner on a crew cab and if so how long does it take? My sun/moonroof drains are plugged or disconnected and gets the fabric very wet after a hard rain. I was hoping to find where the drain tubes exit under the chassis but no luck so they must be shortened or something. I think it's an aftermarket unit installed by the dealer when new.
03 F250 SD Crew, Fx4, Lariat-160K
02 F150 XLT Super Cab-135K
07 Toyota Highlander-35K
2Tight is offline
post #2 of 4 (permalink) Old 06-03-2011, 09:55 AM
HLR4toy's Avatar
The last headliner I removed was out of my '95cc. After taking out most of the plastic trim molding and removing the back window I was able to get the headliner out. Bout 2 hours to take out and 3 hours to put back in.
HLR4toy is offline
post #3 of 4 (permalink) Old 06-03-2011, 01:44 PM Thread Starter
Thanks...sounds like I'll let the sunroof company do it then since it needs a new rim seal anyway.
2Tight is offline
post #4 of 4 (permalink) Old 06-03-2011, 05:14 PM
Hmm taking out the back window seems counter-productive to me. I do trim work for a living and I've never removed a window. Make sure both front seats are fully reclined and you should be able to swing it out the front passenger door. Some cars/trucks go better out the back door. Just takes a little finagalin. Bending it won't hurt it either. As far as drains go once the board is out you'll see rubber Lines on all four corners of the cassette housing. Assuming its a power sunroof. Unhook em and blow air down em and see if that helps.
SOOTWAGON is offline
