How to tell if truck has keyless entry?? - Diesel Forum - TheDieselStop.com
post #1 of 25 (permalink) Old 10-18-2005, 02:26 PM Thread Starter
How would I go about determining if my truck has factory keyless entry installed. When I bought it used there was no key fob but I'd like to know how to tell for sure. Thanks for your help.
2001 F250 XLT w/35K. DP Tuner 6 position chip and supplied PCM (I fried mine!), SP Diesel Exhaust Brake and TC controller, Prodigy Brake Controller, Ford AIS with fender sleeve and Zoodad, Dieselsite Coolant filter kit, Dieselsite External transmission filter kit, Dieselsite heater core mod, Amsoil dual remote filter kit, Roll-n-Lock, Prepump Fuel filter, Open vent CCV, ITP oil crossover mod and overboost eliminator, Factory Tech Valve Body, ATS turbo housing & TAG I, 4" Turbo Back Bully Dog Stainless Exhaust w/5" tip, Cyclops Theft Deterrent, Boost, EGT and Transmission guages in A-pillar, AIH delete plug with code eliminator, Bridgestone Dueler A/T Revo tires. All used to Tow 18' Doolittle Extreme flatbed trailer with '98 Jeep TJ with too much to list.
I enjoy modding my stuff but am done for a while!!! My wife cannot take it anymore!!!!!
OffroadOUFan is offline
post #2 of 25 (permalink) Old 10-18-2005, 02:42 PM
MattBMiller's Avatar
Re: How to tell if truck has keyless entry??
The easiest way would be to call your local Ford Dealer, give them your VIN number and have them get a copy of the original window sticker.
Matt
MattBMiller is offline
post #3 of 25 (permalink) Old 10-18-2005, 02:44 PM Thread Starter
Does it cost?
post #4 of 25 (permalink) Old 10-18-2005, 03:00 PM
Yes, the dealership will charge you for the key and the programing, The dealership here in Logan, Utah quoted me $40.00 per. I got mine thru ebay and programmed it myself.
Carmelo [img]/ubbthreads/images/graemlins/frown.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
01 PSD, CC, LB, Leveling Kit, 35BFG, Daytime driving lights, No Mods yet. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
01PSD LARIAT CC LB Leveling Kit 35BFG No Mods
Bugsyboy is offline
post #5 of 25 (permalink) Old 10-18-2005, 03:07 PM
They shouldn't charge you to tell you whether or not you have it. They will charge you dearly for a key fob though [img]/ubbthreads/images/graemlins/tongue.gif[/img]
Matt
post #6 of 25 (permalink) Old 10-18-2005, 03:07 PM Thread Starter
Does it cost for them to determine if the truck has keyless entry?
post #7 of 25 (permalink) Old 10-18-2005, 04:11 PM
dwelch1's Avatar
My Photos: (5)
if you make a trip to the dealer and they hook their computer up to it to tell you, you will be hit with a hour of labor or so! Do you have another Ford vehicle that has a key fob? try programming it to your truck and see if it takes? if so, you just need a key fob or two!
2015 F-250 Crew Cab, Lariat, 4x4 Magnetic
13K miles so far. Retrax Pro Cover
Relaced My:
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
dwelch1 is offline
post #8 of 25 (permalink) Old 10-18-2005, 05:43 PM
fordmastertech's Avatar
Cycle the ignition key on and off 8 times. If the power door locks cycle you have the key less entry system.
FMT
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #9 of 25 (permalink) Old 10-18-2005, 05:44 PM
Does it seem like it should cost? Do you think Ford can make a cheap buck on it? Do YOU have a funny feeling in your gut that they will charge for it?
If you answered YES to 2 or more of the above questions, the odds arent in your favor....
Jason
Texas A&M University
Class of 2002
2005 F-250 4x4 (FX4), Lariat Arizona Beige/Black two-tone, 5 spd Auto, 6.0L.
agdodge4x4 is offline
post #10 of 25 (permalink) Old 10-18-2005, 06:19 PM Thread Starter
I thought I'd ask in case there was a flat charge. Ford seems as though it is OK to charge nearly twice as much for a CPS as NAPA, International, etc. so I thought I'd ask before I wasted time going and finding out it would cost.
Checking the ignition was simple enough and I don't have it [img]/ubbthreads/images/graemlins/frown.gif[/img] Maybe when the budget allows I'll get an aftermarket one...any suggestions?
post #11 of 25 (permalink) Old 10-18-2005, 06:59 PM
My Photos: (6)
If the truck in question is the one in your signature, then yes it has keyless entry.
If I am not mistaken, all XLT and Lariat Super Duty's from 1999-present had the keyless entry. I have had a Super Duty from each year since 1999 and all of mine have had keyless entry.
Check with dealer or E-bay and buy the keyfobs and program them yourself.
Good luck!
2015 F-150 CC 4x4 Platinum Ecoboost
2016 Explorer Platinum Ecoboost
2017 Fusion Titanium Ecoboost
pstroke is offline
post #12 of 25 (permalink) Old 10-18-2005, 07:03 PM
CSIPSD's Avatar
My Photos: (52)
My 99 XLT did not have it [img]/ubbthreads/images/graemlins/shrug.gif[/img], but I just added a cheap alarm with keyless for $130. Worked just fine [img]/ubbthreads/images/graemlins/biggrin.gif[/img]!!
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning and IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #13 of 25 (permalink) Old 10-18-2005, 07:15 PM
It IS an option on the XLT, I had to order it on my '06.
Ron
aussiekeeper is offline
post #14 of 25 (permalink) Old 10-18-2005, 07:16 PM
dwelch1's Avatar
My Photos: (5)
Checking the ignition was simple enough and I don't have it Maybe when the budget allows I'll get an aftermarket one...any suggestions?
Well, when I ordered my 2004, I didnt know that keyless entry was an option, it came in without it? I installed a crimestopper remote start/keyless entry on my truck, I never gave a remote start much thought, but now that I have it, I love it, its nice to start the truck from inside the bldg at work in the winter time [img]/ubbthreads/images/graemlins/grin.gif[/img]
Relaced My:
dwelch1 is offline
post #15 of 25 (permalink) Old 10-18-2005, 08:21 PM
Delwars's Avatar
My Photos: (5)
Where can I get the keyless entry module for my truck??? It didn't come with deyless entry but I have 3 key fobs from an old truck.
2007 F-350
Lariat
4X4
CC/LB
Firestone Ride-Rite's
Coolant Filter
Edge Insight
Fuel Pressure Gauge
SCT Tuned by Matt@ Gearhead
Delwars is offline
