how turn of interior lites when doors open - Diesel Forum - TheDieselStop.com
Old 04-01-2009, 12:00 AM   #1 (permalink)
Got a neighbor that has a 2002 powerstroke Excursion...she want to turn off the interior lites when the doors are open. Has dogs in cages and leaves doors open for air circulation but wants ti tirn off the interior lites...anyone know how to do this ?
2001 F250 XLT Crew Cab, 2 WD. With 2005 front end, rear view mirror back up camera, Katzkin seat covers, heated and turn signals in outside paddle oem mirrors, hush mat thru-out, door seal mod, 7160 Kenwood gps / dvd, custom dash switches, foglights installed, full lariat interior, new oem carpet, sat radio, rancho 9000 shocks, AIS air intake system. Magnaflow 4" turbo back. Velvet ride shackles. Airlift rear suspension.
seehunt is offline
Old 04-01-2009, 10:13 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
When you open a door, a little button sticks out of the door frame and turns on the interior lights. So to turn off the lights you can mash that button back in - or tape it so it can't stick out.
Several variations on that theme. If you want to fix it permanent for a door, then remove that button from the doorframe and hard-wire the button so the light cannot come on when the door is opened.
But prepare for unintended consequences. If you jummy the switch so the lights don't come on, you will also disable the "door ajar" light on the dash.
SmokeyWren is offline
Old 04-01-2009, 12:13 PM   #3 (permalink)
Aren't they on the time out circuit where the lights shut off after about 10 minutes?
God, Guns & Guts made America free!
Lagrangeville, N.Y.
'97 F-350 DRW dump (sold)
'01 F-350 SRW flatbed
'02 F-550 Dump
Redneck_Steve is offline
Old 04-01-2009, 02:28 PM   #4 (permalink)
My Photos: (19)
My "02 isn't an Excursion so are we talking about the same thing or not? But my switches are built into the door latch in the door. They are also on a timer. They will only stay on for about 10 min. Easiest way I found was to take a phillips screw driver and make the latch close. You may try posting this in the Excursion forum and see if they know better.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
