hub snap ring!!!!!!!!! - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 06-01-2007, 03:34 PM Thread Starter
scrapin's Avatar
How the F do you get the snap ring off of the axle where the shims are!!!!???? I have tried needle nose, screwdriver, lots of F bombs, etc
2008 F250 XLT 6.4 40k miles 4x4, , 3/04' 6.0 F350XL PSD 4x4 dually dump, moog ball joints, 9' min. mt.2 fisher plow----- 2001 F250 5.4 liter gasser 4x4
scrapin is offline
post #2 of 13 (permalink) Old 06-01-2007, 03:56 PM Thread Starter
scrapin's Avatar
Re: hub snap ring!!!!!!!!!
come on anyone have any tricks on this
scrapin is offline
post #3 of 13 (permalink) Old 06-01-2007, 03:58 PM
snap ring pliers
02 F250 PSD 7.3L
Cobra 29 NW ST CB radio
5% tint everywhere with 20% down the whole front windshield
Tymer intake setup
4 inch DP to a 5 inch straight pipe
Air Bag w\ compressor setup
triple gauge pod w\ Di-Pricol Optix (EGT,Boost,tranny temp)
CCV Mod, In-tank mod, Harpoon mod, Airdog Kit, AIH Delete
ITP regulated Return (8LL replaced with AD)
Oilguard Bypass Oil System
Dieselsite Coolant Filter, Fluidampr
ITP boost Annihilator, BTS Trans and T.C.
DP tuner 6 position, ATS housing
02Powerstroke is offline
post #4 of 13 (permalink) Old 06-01-2007, 05:17 PM
Layson's Avatar
My Photos: (28)
Get a good set of the snap ring pliers... I spent alot of time screwing around with the needlenose..and screw drivers.. I think they are like 5-10 bucks for the pliers... It comes off so much easier..
good luck,
Steven
01 F350 CC LB - 14" OUO 525 Series, 38x15.5 Toyo M/T's a 20x12 Weld Cheyenne's. BTS, Terminators, Hybrids...
Layson is offline
post #5 of 13 (permalink) Old 06-01-2007, 05:50 PM
KF6ZVT's Avatar
The only tool that works is a GOOD pair of snap-ring pliers. I've tried all kinds of other stuff, although swearing reduces my level of frustration it did nothing for the snap-rings. (The damned things don't care what you call them, they are just plain stubborn.)
2001 F250 SC 4X4 Blue PSD Auto, Cody Gooseneck Hitch, Rancho Shocks and Steering Stabilzer, Tekonsha Prodigy Controller, Garmin Streetpilot 2610 GPS, Walker BTM, 285/75R/16E, Western Diesel Trans-Pyro-Boost, Pillar Mount, Painless fuse panel, In-tank and Pre-pump mods, Slotted Rear Rotors, Slotted and Cross Drilled Front Rotors, Fumoto Valve, Zoodad Mod, Transfer Flow 46 gal tank, Mag-Hytec Differential Cover, Electric Tailgate Lock, IAH Deleted, Coolant Filter, DP-Tuner 80 hp PCM, CCV Mod, 203 Thermostat, Ford AIS Air Filter
KF6ZVT is offline
post #6 of 13 (permalink) Old 06-01-2007, 05:52 PM Thread Starter
scrapin's Avatar
do i have to take the axle housing out? If so how do u get it out? Also ford gave me 3 new seals where do they go?
scrapin is offline
post #7 of 13 (permalink) Old 06-01-2007, 06:51 PM
Layson's Avatar
My Photos: (28)
Are you just replacing the hub bearings?
Layson is offline
post #8 of 13 (permalink) Old 06-01-2007, 06:55 PM Thread Starter
scrapin's Avatar
the entire hub
scrapin is offline
post #9 of 13 (permalink) Old 06-01-2007, 07:24 PM
Layson's Avatar
My Photos: (28)
http://www.thedieselstop.com/content...20Installation
http://guzzle.rbmicro.com/allube.html
Have you seen these....
I think there should be only one seal for the hub bearing.
Layson is offline
post #10 of 13 (permalink) Old 06-01-2007, 07:28 PM Thread Starter
scrapin's Avatar
There are 3 seals one for the actual hub small o ring, two go on the axle shaft. I am at the point where I need to get the axle out of the housing and I am beating the bag out of the seal to push it thru. It will not budge for me, any suggestions?
scrapin is offline
post #11 of 13 (permalink) Old 06-01-2007, 08:19 PM Thread Starter
scrapin's Avatar
Little more help please, I need to get this beast back on the road
scrapin is offline
post #12 of 13 (permalink) Old 06-02-2007, 12:59 AM
Layson's Avatar
My Photos: (28)
I wish I could help you... Have you gone through the whole ball joint instructions and checked it out.
Sorry dude... Hopefully someone will help out.
You might want to post this in the engine and drivetrain forum. More people might beable to help you...
good luck,
Steven
Layson is offline
post #13 of 13 (permalink) Old 06-02-2007, 10:44 AM
JimTJr's Avatar
My Photos: (20)
Have patient's grasshopper! SNAP RING Pliers will take that off, (If you have not already got a pair by now. Then there is a special tool to replace the large black seal on the axle shaft itself. Some make their own, I borrowed one from the FORD dealer to do mine. (Also if you take the shafts down to FORD, they would do it reasonable I am sure..) The yellow seal goes on the hub, and the small "Dust" seal goes on the differential housing around the axle shaft. SO yes the axle needs to come out. Once you have the ring off, you should just be able to pop it out of the diff.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
