Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 07-10-2007, 07:06 PM   #1 (permalink)
I DARE YOU
To look under your plastic bed rail covers. I have had a cap on mine for almost 3 years and I saw the rust around the ends this spring. The damage is getting fixed and will use line-x to cover the bed rail. The covers are not going back on. The cap covers the mounting holes.I had wanted the covers removed before the cap went on and was told nobody takes them off. I wish I had now. Pic's in link below. I hope all of yours don't look like mine did.
2005 F-350 black 6.0 6 speed DRW 4:10 crew cab 4x4 Long Bed. Every option EXCEPT auto. Line-x. Red Line ATF synthetic fluids. ARE aluminum contractor cap. Donahue Racing 2 1/2" leveling kit W/ 5" rear blocks. Rickson 19.5" wheels W/ Goodyear G-124 265/70/19.5" tires. Savv rear view camera monitor. Firestone Air Bags. N-Fab nerf steps. Alpine speakers. Kenwood DDX-6019 double din head unit. Fluidampr. Accufab intake elbow. MBRP 304 cool duals with muffler delete pipe. Work truck.
http://community.webshots.com/user/rocknmud
ROCKNMUD is offline
Old 07-10-2007, 09:31 PM   #2 (permalink)
Re: I DARE YOU
Yeah. I always heard that about plastic bed liners. I almost got into a business with sprayed in bedliners. A friend and I were a loan request away from it, then we both moved away from each other. I have a sprayed in, but the place I bought it from put a plastic over the top of it. I am scared to pull up the plastic to see the entire mess underneath. Good luck with the fix.
David
1999 F350 Super Duty Dually. Completely stock.
There are 10 types of people in this world; those that understand binary and those that don't.
surftout is offline
Old 07-10-2007, 10:14 PM   #3 (permalink)
JimTJr's Avatar
My Photos: (6)
Re: I DARE YOU
That is not from the plastic bedliner, it is from the factory plastic caps.... man. What do you do though? There are all those slots, for mounting them, you can't eliminate them really, you going to linex it then reinstall them?
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 07-10-2007, 10:18 PM   #4 (permalink)
Re: I DARE YOU
I have some sharp lookin diamond plate ones that are right on top of the plastic ones. No rust for me.
2000 F250 7.3, AFE stage 2, 4" custom straight pipe, shift kit, DS Predator tuner, IC foil MIA, CCV mod, ATS compressor housing, hood insulation MIA, DIY boost gauge and over boost eliminator, 195,000 miles and counting.
redfishman17 is offline
Old 07-10-2007, 11:39 PM   #5 (permalink)
Re: I DARE YOU
I have the same thing, except the corners near the tailgate have been hit/bent, and now rub on the paint, therefore I have rust spots..
2002 F350 Reg Cab,4x4,7.3L PSD,6Spd. 03+ TT Mirrors. 2 gauge pod with Isspro pyro and boost gauges. AIH Delete. HPX Crossover. CCV. MBRP 4" exhaust. ITP Overboost Annihilator. AFE Stage 2 PG7 Intake. DP tunes: Stock, Hi-Idle, 60T, 80E, 120R. Waiting to Install: ATS housing, 203 Tstat, BBHA, Dieselsite boots.
http://community.webshots.com/user/dieselgeek
nhorne is offline
Old 07-11-2007, 01:01 AM   #6 (permalink)
Re: I DARE YOU
I ain't lookin, scared to. Ostrich theory.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
Old 07-11-2007, 02:26 AM   #7 (permalink)
Re: I DARE YOU
Reading posts like this makes me appreciate the dry desert heat and constant sun. I'll probably be dead of skin cancer before my truck ever gets rusty.
2005 F250 PSD Lariat 4x4 FX4 3.73, MBRP 4" turbo-back
ISSPro EGT and Tranny
Oilguard Bypass
SCT Tuned by Innovative
ryandye is offline
Old 07-11-2007, 05:32 PM   #8 (permalink)
FINE69's Avatar
Re: I DARE YOU
I looked, not one single scratch! No rust, no messed up paint! You may be having problems because of your cap. All that weight of the cap, plus ladders is rubbing off the paint, causing the rust.
2005 F-350 4x4 Supercab, Lariat, LWB, SRW, FX4, 6.0, Auto. Oxford White/Arizona Beige. MBRP SS Turbo-back Cool Duals-Cat Delete Pipe, DieselSite coolant filter, Mag-Hytec dif cover, Royal Purple Syn. lube in axles, 325-65/R18 Nitto Terra Grapplers on Weld Evo Cheyenne-8 18x8.5 wheels. Fabtech 2" Leveling kit, Bilstein 5100's. Precision Billet grille, Lund Interceptor, Husky liners, Rhino liner, Weatherguard toolbox, 8' Western Ultramount Poly Pro snowplow, 15% tint. Built 12/04
http://community.webshots.com/user/FineFord
FINE69 is offline
Old 07-11-2007, 06:11 PM   #9 (permalink)
Re: I DARE YOU
I agree with you on the cap installed over the plastic covers is most of the problem. The cap loaded with tools and corner bead is heavy. It was installed with 3- 3/8" bolts on each side. Bolted at all corners and in the middle. Even if someone is installing a tool box they should consider cutting the bed rail cover at the box so it is not under it. After seeing the top of the bed rails it is no wonder Ford puts them there. The steel is very thin and would dent easy.
ROCKNMUD is offline
