Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 08-19-2008, 08:45 PM   #1 (permalink)
Ignition Key Bell
My ignition key bell stays on sometimes in my 2002 F250 after I remove the key. If I jiggle it it goes off. Is there a way to adjust this
diccou is offline
Old 08-19-2008, 09:15 PM   #2 (permalink)
chuckster57's Avatar
Give this a try
It is "dry' so it doesn't promote the innards of the lock cylinder to "stick" . A little "puff" and then insert/remove the key quickly a few times to "lube" the works.
Graphite Store:*Graphite Powders and lubricants • Fine powders • *Graphite Tube-o-Lube
You don't have to buy from here. I believe it is still available at most hardware stores.
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
chuckster57 is offline
Old 08-19-2008, 09:54 PM   #3 (permalink)
Thanks I will give it a try
diccou is offline
Old 08-21-2008, 04:55 PM   #4 (permalink)
Any way to disable the bell entirely? I hate that thing. Damn nanny-state we live in. I got keyless entry! What do I care if my keys are in there or not!!!
Looked through my owners manual and found nothing. I'll search around some more...
jschuman is offline
Old 08-21-2008, 05:40 PM   #5 (permalink)
My old '86 gasser had the annoying "chime". I opend the doors, put in the key and went loking of the source of the scourge. Found it under the glovebox. It may be in a different spot on the newer ones, when I did find it, I unplugged it and put it in the glovebox for the next owner. Gave the truck to Community Hospice this spring and the "chime" was still in the glovebox.
Old 08-21-2008, 06:31 PM   #6 (permalink)
Searched "ignition chime" and found it....
Easy fix on the 03'!! Wish I had done that about 5 years ago!
Slide the cylinder out, take the little metal clip out, re-insert the lock and awaaaay we go!
DICCOU did you try sliding the cylinder out and seeing if there is anything amiss with the lock assembly? there are a few parts in there, so I would at least pull the cylinder and look to see what you got? Just an idea.
Sorry for hijacking your thread!
jschuman is offline
