interior light comes on when slowing down - Diesel Forum - TheDieselStop.com
Old 11-08-2009, 09:20 PM   #1 (permalink)
I know it sounds odd, but my interior lights are acting goofy. tonight while driving around the interior lights would come on when I got below 15mph. I also noticed that on one occasion my blinker started to blink fast as if I had a burned out bulb, but then went back to a normal blinking pattern, and sometimes the key in the ignition chime works and sometimes it doesn't, and when I shut it off to fill up the tank the lights on chime was sounding even thou the headlights were off.
Would a bad ignition switch be a possible cause? Whatever the case, I'm thinking that I have some issues in the steering column.
In any case is there a fuse for the interior lights, and if so I need to know what space it is in because I don't have an owner manual.
2009 Flex limited, everything except navigation, and the cooler in the back armrest.
2002 Ford Ranger, 4.0l 4X4, lifted, 35" tires
1999 Ford F350 ex. cab, long box, 4X4, 6 speed, manual hubs,171k, build date 7-98
NEFORDFAN is offline
Old 11-09-2009, 11:06 AM   #2 (permalink)
jgarden's Avatar
Solution: Speed up? (sorry couldnt resist).
Seriously: odd problem, I cant remember reading about a similar problem here. Good luck with it. Please post back if you find the solution.
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
Old 11-15-2009, 10:26 AM   #3 (permalink)
I've had this problem a few times. The door open warning lamp switch is stuck making the truckj think the doors are open. The lamp shuts off around 15 MPH and comes back on around 3MPH? I've had luck spraying some lube (WD, break free, RemOil, etc.) in your door latch area and around the little black rod on the front side of the door. Sorry, I can't be more specific as it's been over 7 years ago since it last happened.
Brad
('99 F250 XLT 4x4-SOF SC LWB SRW AT 3/98 Build XLE4), diablo 78 hp, ADPerformance 2 stage Propane, Detroit No-Spin lockers-rear, ARB lockers-front, diablo $hift valve, tricumulator spring pack, AICM, Amsoil air filter, BFG 285x75 MT's
BCate is offline
Old 11-15-2009, 12:22 PM   #4 (permalink)
fxdwgi's Avatar
Sounds like you have a water leak somewhere and it is dripping on the GEM module.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 11-15-2009, 03:24 PM   #5 (permalink)
get some WD-40 and spray it on your door latches and their contact points like BCate said. simple solution!
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
browningbuck225 is offline
