Interior light stays on???? - Diesel Forum - TheDieselStop.com
Old 11-27-2012, 02:54 PM   #1 (permalink)
I have a door sensor that must have gone bad. When I shut the door the dome light stays on and the light that shows the door is open on the dash stays on all the time.
What are the steps to figure out which sensor is bad and is there a sticky or some pictures one can point me to to get this fixed? How does one take the door panels off or do you even need to do this? The truck is a 2002 f-350 crew-cab and I am thinking the driver side rear door is the problem because that is the only door I can open and close without the light getting activated. All the other doors will turn the light on when opened and the truck will shut it off either when driven or after 15 minutes of waiting.
2002 F-350 7.3 XLT, CC, SB, SRW, 4x4 with 220k on it.
Pretty much stock except, 203 themostat, DIY Air intake and DP tuner.
dieselstrokin is offline   Reply With Quote
Old 11-27-2012, 03:56 PM   #2 (permalink)
When this has happened to me I was always able to fix it by simply spraying wd-40 into the door lock latch assy. Just open the door and spray into the door latch without taking anything apart then open and close the door several times and see it works. My experience has mostly been the drivers door that was at fault but it could be any door . Cheap thing to try before replacing door latches or switches, good luck.
Sent from my Transformer TF101 using AutoGuide.Com Free App
2006 F-250 RED XLT SPORT SC PSD 4X2 52K
2000 F-350 RED LARIAT CC PSD 330K 4X4 (SOLD)
1999 F-350 WHITE XLT CC PSD 130K 4X2 (SOLD)
1997 F-250 RED XLT STD CAB PSD 30K 4X4 (SOLD)
LOVE ALL MY PSD'S!!!!!
Mytwuk is offline   Reply With Quote
Old 11-28-2012, 11:38 AM   #3 (permalink)
Thanks for the suggestion----IT WORKED!!!!!
Love easy and cheap fixes!!
Old 11-28-2012, 04:16 PM   #4 (permalink)
Your very welcome, glad it worked!
