Interior water leaks - Diesel Forum - TheDieselStop.com
Old 03-05-2005, 01:09 PM   #1 (permalink)
Hi,
I'm having a bad problem with the drivers floor soaking wet anytime it rains. I've sealed all the holes I could find, replaced a transfer case shifter boot and still this morning the drivers floor was swimming. This time, the truck wasn't driven, so the flooding isn't forced in by driving.
It looks like in MIGHT be running down the inside of the firewall right in front of the pedals. Anyone else have this problem? Could it be a windshield seal problem? Big problem this year with all the rain in SoCal. Been thinking about pulling the carpet and Rhinolining...
Thanks,
Ken '00 350 supercrew 4x4 7.3 manual
lipodog is offline
Old 03-05-2005, 02:34 PM   #2 (permalink)
fordmastertech's Avatar
Re: Interior water leaks
Sounds like a windshield problem to me. I see a lot of them leaking and they eventually kill the GEM module on the back of the fuse panel.
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 03-05-2005, 03:19 PM   #3 (permalink)
Hmmmm, Ok,I'll look there. I've got the windshield wiper off, the plastic piece off, the front tire off, the inner fender out and i was thinking it might be the sealer/seam between the fender and the firewall. I'm thinking it was involved in enough of an accident to open that seam a bit. I've been running the hose I THINK below the lowest level of the windshield and I see the dribble of water running along the inside of the firewall right along the seam. I'll try and post a few pics...Be right back.
Truck: 2000 F350 4x4 Supercrew manual
Mods: Pyro and boost gauge, 4" Exhaust, luk, diablo chip, Tymar intake.
lipodog is offline
Old 03-05-2005, 03:21 PM   #4 (permalink)
Oh ya, btw, what is that electronic box hiding up under the inner fender?
lipodog is offline
Old 03-05-2005, 03:33 PM   #5 (permalink)
Ok, definately not from the windshield. Wish it was. There is almost no way to get to that seam. Too much metal in the way.
lipodog is offline
Old 03-05-2005, 05:09 PM   #6 (permalink)
[/ QUOTE ] IDM Injector Driver Module
[/ QUOTE ] Seam leaks are the worst to find and repair. There is no rhyme or reason to them
Old 03-05-2005, 10:02 PM   #7 (permalink)
Thanks for the info. Interesting place to put a computer. I've never had a seam leak before. Very difficult to get to. I silicon sealed everything I could get to. Hope it works. Otherwise, guess I'll have to move out to the desert!
lipodog is offline
Old 03-06-2005, 01:17 PM   #8 (permalink)
I hope you're using the genetic term Silicone. Use a NON Silicone seam sealer because silicone will peel off at some point and nothing will stick where silicone has been. Seam Sealer will last forever.
Wayne B
2000 F-250 XLT PSD 4X4 ESOF Auto, SC, LB, Gauges, Mag-HyTech Trans Pan & Rear End Cover, <font color="red"> (((XM))) Inside</font>, ATV Racks w/ Two Kawasaki Prairie 400 4X4's sitting on them, 25' Rockwood TT. Ashburn, Va. Member # 103 Pictures
www.CarpathiaHost.com
Wayne B is offline
