General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
I keep hearing a "jingling" noise while driving... more apparent when going over bumps. It appears to be coming from the front end. What in the wide world of sports is it? Caliper brake pad pins? Sway bar seems tight after a quick driveway inspection. Any ideas?
Another jingler here. There was a thread about this a long time ago that said what it was. I was going to check mine and forgot to do it and now I can't remember what it was. Maybe someone with a better memory than me will chime in.
'02 F250 XLT CC Shorty SRW 4X4, Auto, SCMT 80, AIC, WD pyro, boost & tranny, Jack-It with 4" blocks, AFE, Prodigy, 4" Turbo Back Straight Pipe, 285/75/16 Cooper STT's, Sonnax/Tricum, SP Diesel EST
I had the same jingling noise in my 1990 F-350 and found that the nut in the lower center of the left front coil spring was loose. This allows the large washer to bounce around and make the noise that you are hearing.
In order to tighten this nut I had to jack the truck to allow enough space between the coils to get a wrench in there.
Hope that this helps.
Capt Ron
May 2003 F-350, CC, DRW, 6.0L, 6sp man, LB, Al Wheels, Moon Roof, 52gal tranfer tank. Hitches: Draw-Tite 16K 4X and B&W GN, 8040lbs GVW. Towing 35' Newmar Kountry Star 5th Wheel Camper, 14,000lbs GVW, or Wells Cargo 24' Car Hauler, 12,000lbs GVW.
mine does it too not sure what it is has done it for a year now. rumble strips you can hear it
2001 Ford F-350 crewcab long bed srw black gauges boost and pyro 125 hp chip adjustable 10k-3.9k mod. Straight piped 4 in lift with 35`s X-
Terrain. Aceton emblems <font color="red"> Everyone dies but not everone lives </font> http://photos.thedieselstop.com/show...=39254&thumb=1
