Key FOB programing question??? - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 05-25-2007, 06:35 PM Thread Starter
I will post pics soon, I ended up buying the Beige 2001 F350 4x4 Crew Cab, short box XLT package.. The one that has 64,311 miles on it now. I have a few extra of the Ford key FOB's How do I program them to work with this truck? It does has electric locks. thanks, Chuck
2003 BLACK Excursion Limited 7.3 4x4 w/DVD entertainment center, rear captians chairs, 3.73 limited slip. 4" MBRB Stainless Exhaust, AFE stage II intake, DP F5 Tuner, 4.5" Donahue lift, Rolling on 18" Jesse James Lawless 8's wrapped by 35" Toyo Open Country Mud Terains and airbags, Prodigy brake controller.
2002 BLUE F350 XLT 7.3 4x4 Crew Cab short box, BTS Tranny, 6.0 tranny cooler, 4" Silverline Stainless exhaust, S&B intake, DP F6 Tuner with 9 tunes. Line X, B&W turnover ball, Prodigy brake controller.
1968 Chevy C-10 Short Bed PRO-STREET 500+CI BBC
1991 Honda CRX-SI (Black Also)
2002 John Deere Gator Diesel 6X6
2003 Limited edition Cannondale Cannibal- With colors that woulnt run, RED, WHITE and BLUE #0000016
Owner and Dad of Godspeed MX racing. #269
1BADF350 is offline
post #2 of 17 (permalink) Old 05-25-2007, 06:39 PM
Re: Key FOB programing question???
[/ QUOTE ]turn the key on and off 8 times stoping on the on position and the locks will lock and unlock then u push a button on the fob
2001 f-250 7.3cc auto. 4x4,
-4'' straight pipe
-homemade intake
-gauges
-dp chip(80eco,and 120race)
-tranny rebuilt by kosub.(my towns bts)
samdust is offline
post #3 of 17 (permalink) Old 05-25-2007, 07:08 PM Thread Starter
Thank you Sir... [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Amazing how this little things excite us so... [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1BADF350 is offline
post #4 of 17 (permalink) Old 05-25-2007, 07:34 PM
All the owners manuals and stuff here, in case they are not with the truck.
http://www.thedieselstop.com/faq/9497faq/download/2001/
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #5 of 17 (permalink) Old 05-25-2007, 11:54 PM
I have a 2001 also. It has electronic locks. How do you find out if it has the equipment for the key fob?
01 F250 SD 7.3L. Black, AIS Filter system, 6spd, Double/Single stainless rollbar, zoodad mod, 4" turbo back cool duals (sounds great), stainless grille guard,
Tipher is offline
post #6 of 17 (permalink) Old 05-26-2007, 10:06 AM Thread Starter
As long as their factory ford locks, Find some Ford key FOB's (ebay)and the will work. I think we can even use the new 2004 and up exterior door number key pad style.
1BADF350 is offline
post #7 of 17 (permalink) Old 05-26-2007, 02:42 PM
Well I have not bought a key fob. But I did try the key switch 8 times. The locks did not cycle so I am assuming it must not have the capability for a key fob.
Unless i was doing something wrong.
Tipher is offline
post #8 of 17 (permalink) Old 05-30-2007, 12:54 PM
I too cannot get my truck to enter the key fob programming mode. However, I know mine has remote keyless entry because I have one funtioning fob. I was just trying to program a spare.
I cycled the ignition 8 times like it says, and got nothing. I've done this successfully on a couple of other Fords, so I'm not sure what the issue is with my '03.
2003 F-350 CCSB SRW 6.0
cmccarthy is offline
post #9 of 17 (permalink) Old 05-31-2007, 02:09 PM
[/ QUOTE ]keep turning it till the locks do something. off on off on make sure its hitting the on position it has to work.
-4'' straight pipe
-homemade intake
-gauges
samdust is offline
post #10 of 17 (permalink) Old 05-31-2007, 10:38 PM
Banned
It is not only the number of times the key is turned to <ON>....
C'mon, guys, read all of the appropriate section.... It will usually start out with unlocking the doors with either the remote or the door button... without this step, it will not even attempt to enter programming mode....
Some may require the door to to be open... some may require the door to be closed.... some wont matter... but this also needs to be done the way it needs to be done and the manual will spell it out.....
GrampyJim is offline
post #11 of 17 (permalink) Old 06-01-2007, 07:31 PM
HoneyShucks's Avatar
Ok fellows, try this.
Cycle your switch 8 times within 10 seconds. Count the dash lights on and off and on the 8th cycle, leave them on. you than have 20 sec to press any key on your FOB [img]/ubbthreads/images/graemlins/grin.gif[/img]
2001 Ford F-250 PS, CC, 2/w drive short bed, auto(BTS upgrade), Banks Stinger Plus and exhaust brake, TurboSaver, HX,Hutch mod/pooned, K&N FIPK, Mag-Hytec trans and diff pans, Cyclone fan, doodad, Bilstein shocks, Air-lifts front and rear, dp-Tuner F-5 chip, Fleetrite/203therm, fuel regulator shim, GOS headlight harness/silverstars, Bob's coolent filter, Rotella Syn w/single by-pass.
HoneyShucks is offline
post #12 of 17 (permalink) Old 06-21-2007, 01:55 PM
I still have not got this to work. I think mine must not have it on it. But it says it is standard in these trucks. But it sure wont cycle the locks after 8 times.
Tipher is offline
post #13 of 17 (permalink) Old 06-21-2007, 11:26 PM
JimTJr's Avatar
My Photos: (20)
You gotta cycle the key 8x in something like 10 seconds,, not easy to do. Took me 3-4 tries.
I don't think the door can be open, and you have to start with them either locked or unlocked, not sure which...
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #14 of 17 (permalink) Old 06-22-2007, 10:16 AM
My Photos: (5)
Yeah, you have to be quick. The complete instructions are found in the owner's guide.
AutoJim
Former Cooling Guy
'99.5 F350 Lariat CC SRW 4x2, 7.3L 4R100
'99 Mustang Cobra, SCCA Solo2 E Street Prepared
'97 Dodge Neon, SCCA ITA/STU/EP Club Racing
Now I do subsea ROV tooling.
AutoJim is offline
post #15 of 17 (permalink) Old 06-22-2007, 03:12 PM
I also read here, that all the fobs have to be programed at the same time [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
