General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
I have a 1999 PSD with keyless entry. I cannot lock/unlock the doors while the engine is running. Is there a modification to lock/unlock the doors with the engine running? So far, I haven't been able to find any solutions.
Sorry but the key fobs are disabled while the engine is running, but you can purchase the door key pad from Ford, and get it wired to the system, or just carry another key in your pocket.
Will-
William Haskell
Semper Fi!
2001 F-250 4x4 Super Cab, PSD, 54/78hp Diablo Delta Chip, Edge EZ, AFE Intake, Banks Monster Exhaust, B&D Power X-Monitor, Wicked Wheel, BTS Trans, and a bunch of other goodies. S.L.A.P.S. "Officer at Large" Diesel Stop Pics
Pics at http://www.fordtruckworld.com/mygallery.asp?id=8195
Only later builds 2001+ ? can you work the keyless with the engine running.
Lots of 1999 owners locked themselves out at the pumps or convience stores.
Nat
2005 F-350 CC SWB SRW Harley; 2004 F-350 Chestnut/tan 4X4 King Ranch CC SWB SRW 2004.25 6.0 PSD
Past PSD's All 4X4
1999 F-250 SC SWB 10-98 build
1999.5 F-250 Lariat
2000 Excursion Limited PSD
2002 F-350 CC SWB Lariat
2002 Excursion Limited Ultimate Premier
2004 Excursion Limited 6.0 POS
Son's F-250 SC SWB PSD
2005 F-350 King Ranch CC SWB 6.0 POS
I have a June 01 build, and I can't use the key fob if the motor is running. Would be nice though.
Will-
William Haskell
Semper Fi!
There is no way to disable it in the 2001 and older trucks. In 2002 and newer models, the GEM was replaced with a newer component call the VSM (vehicle security module). The GEM did not allow the remote FOB or keypads to work, but the VSM that replaced the GEM's function was wired/programmed differently. They are not swappable and there is no way to interchange them. Now if you get an Excursion GEM out of a 2001, you can wire a keypad in. It is compatible with the trucks and a direct swap with a few minor modifications.
