Kill Switch - Diesel Forum - TheDieselStop.com
Old 01-01-2013, 03:39 PM   #1 (permalink)
Kill Switch
Any one know where to tie in a kill switch. I have a 03 6.0 I want to kill the key when its parked .I want to put the switch under the seat or dash or--- any ideas.
i
i
indian347 is offline   Reply With Quote
Old 01-02-2013, 11:21 AM   #2 (permalink)
Homegrown's Avatar
I can't tell you where to mount it, or I'd be giving up my secret location. If you have the auto transmission, there'll be a plug under the dash with a jumper across the pins where the clutch safety switch would wire in. Put a hidden switch across these pins and the starting circuit will be interupted just like trying to start a manual trans truck without pushing the clutch in.
FOKISD Charter Member from Hillsboro, OHIO
'01 F-350, XL, SC, LWB, V-10, 4R100, 3.73 LS, High Back Buckets, TT Mirrors, Roof Lights, Camper Package - Check my Photo Gallery for modifications. Michelin LTX M/S 2's on Mickey Thompson Classic II's, A.R.E. DCU cap, Reese Titan V and Draw-Tite front reciever, Audiovox cruise control, Wolf center console, Truck-Lite rear ID bar, Hella FF75 driving lights. Bilsteins on each corner.
Homegrown is offline   Reply With Quote
Old 01-02-2013, 01:04 PM   #3 (permalink)
Springerpop has a good writeup about his kill switch which incorporates a true "hidden" switch activated by passing a magnet close to it. You can modify his plans to break the electrical circuit of whatever you need. See the link below:
SpringerPop's Disabler
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, CCV Canister Style Mod, AIS w/sleeve, Fuel filler mod, GOS headlight harness, Hella 80/100s, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny, 26 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Donaldson ELF7405 oil filter, billet thermostat housing.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DTRS and BPP kill switches, DIY "pitstop" switch.
http://community.webshots.com/user/l...host=community
losfinch is offline   Reply With Quote
Old 01-03-2013, 07:50 AM   #4 (permalink)
kill Switch
Thanks much gentleman . Jim
