Leaking gear box - Diesel Forum - TheDieselStop.com
Old 06-21-2006, 09:42 PM   #1 (permalink)
Leaking gear box
My steering gear box is leaking on my '99 F250. It looks like the leak is coming from under the plate on the top. This plate has 4 bolts and the adjustment screw/nut in the middle. Is it possible to remove this plate and use some silicone or something to reseal it? or would that end up messing something up? Am I looking at a new gear box instead? I am using synthetic ATF in the power steering system if that makes any difference. Thanks.
99.5 F250 4x4
2000 Excursion 4x4
http://community.webshots.com/user/mmsafd
mmsafd is offline
Old 06-21-2006, 10:06 PM   #2 (permalink)
Re: Leaking gear box
Sorry I cant answer about how to fix but just wanted to let you know if you do need to buy new one I suggest www.redheadsteeringgears.com/ I have had two stock ones and they wondered over the road and sucked. This one was much better...just food for thought
Jan 04 6.0 CC LB 4x4 Wedgwood blue
DR 6", 4.5 hanger + mini springs, TOYO MT 35x17, Rubicon Volt 8's
rstaichi is offline
Old 06-25-2006, 12:02 AM   #3 (permalink)
So does anyone have any experience with removing that top plate? It sure weems like a waste to replace the entire box if I don't have to. The truck is at 72k and the box is still pretty tight. I just don't know what will be inside there. I am afraid of opening the plate and gears and springs falling out. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
99.5 F250 4x4
2000 Excursion 4x4
mmsafd is offline
