Lens on Speedometer Display
I bought my 2004 F-250 and the previous owner must have spilled some solvent on the display dulling it in spots. I have polished it out as best as I could with plastic polish. The question here is two fold. Can the lens be removed, I removed the dashboard but the lens is "glued" to the display, or is the a better way that plastic polish to get rid of the solvent runs.
Martin - Fort Worth, Texas
 2003 F-250 FX-4
Build Date February 23, 2003
166,500Miles
Rotella 5W40 Synthetic - the only oil
Hot Shots Secret
Diamond Mfg. Brushguard - Made In Texas
4" Banks Turbo Back Exhaust
EDGE CS with Attitude and Turbo Down Timer/Pyro (Set on Level 3)
Upgraded Oil Cooler International 1171962R1 (Dec 2009)
EGR Block-off Kit (Dec 2009)
Upgraded HPOP International 2591022C91 (Jan 2011)
Upgraded Oil Drain Tube Ford 6C3Z-9T515 (Jan 2011)
New Steering Stablizer (May 2011)
Upgraded Fuel Pressure Regulator (blue spring) Ford 3C3Z-9T517-AG (June 2011)
Rousch/Autometer Electronic Fuel Pressure Gauge (July 2011)
ProForm Fabrication Front Leveling Shackles (July 2011)
Dfuser Coolant Filter (July 2011)
New Vacuum Hub Solenoid 7C3Z 9H465A (October 2011)
New Motorcraft Thermostat RT1169 (November 2011)
Bilstein 5125 Shocks 33-185569 Front and 33-185552 Rear (December 2011)
New Sway Bar Links and Bushings Front and Back (December 2011)
ARP Studs with Ford Motorcraft Head Gasket (December 2011)
Moog Ball Joints K860T and K80026 (December 2011)
