lights schematic...Anyone? - Diesel Forum - TheDieselStop.com
Old 10-16-2009, 01:43 PM   #1 (permalink)
Im trying to find the reverse lights wire but having trouble. Does anyone know the color of the wiring. Trying to add a few more so I don't back over anything else that I shouldn't.
Thanks in advance.
grnbldr3 is offline
Old 10-16-2009, 02:25 PM   #2 (permalink)
Teknobenji's Avatar
Reverse Light black/pink + relay box under hood
1999.5 F250 Crew 4" Magnaflo Turbo back exhaust, DIY intake, AIH Delete, HPX Line, zoodad mod, Wicked Wheel, Gauges (Tranny, Boost, EGT) DP-Tuner ITP "In-Tank" mod and prepump filter, RiffRaff FRX Regulated return, foil delete and lighted cup holder...that's right - lighted cup holder.
Teknobenji is offline
Old 10-16-2009, 05:05 PM   #3 (permalink)
klhansen's Avatar
My Photos: (169)
Thanks in advance.
Depends on what year your truck is.
99-01 is black/pink
02+ may be different.
If you're adding backup lamps, you need to use a relay to activate them from a separate fused circuit. The circuit for your stock backup lamps is fused at 10A (99-01 trucks). Or you could just use the trailer backup lamp circuit if you don't tow a trailer with backup lamps. It already has a relay in place and is wired to the back of the truck. On a 99-01 truck it would be Black/Lt green wire (usually tagged at the connector for the trailer plug-in.) That circuit is fused at 20A and also carries the trailer running lamps.
Hard or no-start? Check Here
klhansen is offline
Old 10-16-2009, 10:48 PM   #4 (permalink)
Teknobenji's Avatar
should be black/pink up through '06
