Limited Slip Differential - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 07-17-2006, 03:37 PM Thread Starter
I'm suppose to have the 3.73 Limited Slip Differential in my truck. My understanding of a limited slip is that I shouldn't be able to sit and spin just one of the rear wheels on a slippery surface. It should act just like a true posi rear end. I've also heard that if you jack up one tire, you shouldn't be able to spin it freely by hand either. I tried this with the tranny in neutral and only one tire and the drive shaft spin at a time. The rear wheels are not locking together like I think they're suppose to. If I brake stand the truck, only one tired spins. I first noticed the problem on went grass in 4 low trying to pull another truck. Only one rear tire would spin and one front. I know only one in the front spinning is normal but both my rears tires should be spinning.
I think my limited slip is not working. Am I correct?
2005 F-350 FX4 XLT 4x4 CC/LB Torqshift with Diamond Back ATV Truck Cover, Zoodad Mod
Banks Power PDA with Monster Exhaust and Accufab intake elbow from Innovative Diesel
35x12.5x18 Toyo MT with 2.5" leveling kit, 2005 Weekend Warrior FB2200 for the toys
tzurick is offline
post #2 of 18 (permalink) Old 07-17-2006, 04:04 PM
Re: Limited Slip Differential
Others will chime in on this, but it sounds like a stock Ford limited slip. They are relatively useless.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #3 of 18 (permalink) Old 07-17-2006, 05:18 PM
You are correct, sir. My '02's LS rear was much better. This one just plain sucks. I like this truck in all other regards.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
torino73 is offline
post #4 of 18 (permalink) Old 07-17-2006, 08:00 PM
Bumpy's Avatar
Just apply the break a little to load up the clutches and it will work. Sound weird and definatly not a good design but it will work. On a side note my LS rear works well in loose sand. I think maybe they need some use now and then.
2006 F-350 Crew Cab Lariat 4x4 6.0 Power Stroke diesel
Bumpy is offline
post #5 of 18 (permalink) Old 07-17-2006, 08:01 PM
ta152h0's Avatar
Check your Diff code on the doorpost. If you have the limited slip it should read " C3". If not, you have the open differential. For what it is worth, i had to order mine limited slip.
Wolf
Kentucky built 2004 Silver F-250 XL Reg Cab PSD, 4X2, bench cloth seat,air conditioning, 6 spd Manual, 3.73 LS,Line-X , FORD receiver, Prodigy brake controller,towing option,( put together on Monday, March 29, del April 9 2004) 62000 miles
ta152h0 is offline
post #6 of 18 (permalink) Old 07-17-2006, 11:21 PM
[/ QUOTE ] You don't have a L/S
toalpi is offline
post #7 of 18 (permalink) Old 07-18-2006, 12:38 AM
For the record, a "posi" rear end is the same thing as a "limited slip".
Contrary to some peoples experiances, my factory LS has been working fine and has gotten me over some pretty rough terrain. I am aware though, that it isn't a full locker like I have in my Bronco and don't expect it to function the same.
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
post #8 of 18 (permalink) Old 07-18-2006, 07:14 AM
SmokeyWren's Avatar
My Photos: (45)
Nah, he has a 2005. Per the workshop manual, for 2005 the axle codes for PSD pickups were:
37 3.73 non-limited slip - F-250
41 3.73 non-limited slip - F-350 SRW
3L 3.73 limited slip - SRW
4N 4.10 limited slip - DRW
4L 4.30 limited slip - DRW
For 2004 and older PSDs, a code C3 rear end was:
C3 4.30 limited slip, F-250/Excursion w/V-10 gasoline engine [img]/ubbthreads/images/graemlins/shocked.gif[/img]
SmokeyWren is offline
post #9 of 18 (permalink) Old 07-18-2006, 07:46 AM
I think it should read
41 4.10 non-limited slip
Jim
2009 F250 PSD 4x4 CC LB KR
2007 Suburban LT3
2007 Yukon XL Denali
2005 F250 PSD 4x4 CC LB KR
JimJoe is offline
post #10 of 18 (permalink) Old 07-18-2006, 08:06 AM
SmokeyWren's Avatar
My Photos: (45)
4.10 non-limited slip is not available on a PSD pickup. You can get it on a gasser, but it's code 32.
Perhaps you're confusing the code on the axle tag? On the axle tag, if the first two digits of the second line begin with 4_1, then that's a 4.10 non-limited slip. But the axle code on the vehicle certification sticker will then be 32.
post #11 of 18 (permalink) Old 07-18-2006, 08:54 AM
Got it [img]/ubbthreads/images/graemlins/smile.gif[/img]
Jim
2007 Suburban LT3
JimJoe is offline
post #12 of 18 (permalink) Old 07-18-2006, 10:19 AM Thread Starter
Well the code on the door is 3L so maybe they forgot to install the right hardware [img]/ubbthreads/images/graemlins/smile.gif[/img] Anyways, it's at the dealer today so we'll see what they say. I talked to a tech there last week about it and he seemed to think I shouldn't be able to turn only one wheel if I jacked up one side of the rear. I'll keep you all posted. You would think a truck with the FX4 off road package would be able to drive on wet grass in 2WD without getting stuck.
tzurick is offline
post #13 of 18 (permalink) Old 07-18-2006, 11:43 AM
[/ QUOTE ] Let me rephrase that; You don't have a functional L/S. How many times have you been stuck and or spinning with one rear wheel?
toalpi is offline
post #14 of 18 (permalink) Old 07-18-2006, 12:14 PM
fwiw, I have (very) limited slip on my 2000. I've never been happy with it. I can spin the tire on a soft shoulder if one tire is on pavement and one is on the dirt shoulder. I only have 2wd. What I have found beneficial is to start out in 2nd gear instead of 1. Seems that first gear in the auto is pretty low, so starting out in 2 doesn't spin the tire at all. This has gotten me out of several jams.
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, BAK RollX bed cover, Bed mat, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, undercoated, 156k somewhat trouble-free miles (so far), Edge Evolution (60 HP setting), Pioneer DVD/CD/iPod/XM satellite, backup camera
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2) and tension pullies, all 4 power lock actuators, water pump, air conditioning lines and compressor, battery cables, replaced the leather oem seat covers with very good leather replacements (found a great place and price from a place in Dallas that custom makes them)
2016 Subaru Outback (Wife's commuter car)
2016 Starcraft Autumn Ridge 29ft TT
short_stuff is offline
post #15 of 18 (permalink) Old 07-18-2006, 02:30 PM
ta152h0's Avatar
Finesse is a virtue [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Wolf
ta152h0 is offline
