Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 08-18-2005, 08:23 PM   #1 (permalink)
Lock actuators
Hey I need to replace my door lock actuators, and I remember reading a post about some good generic ones online, but can't find the post in a search. Does anyone know where to look?
Thanks,
Matt
99 F250
mods include a missing muffer and a power chip.
STbasco is offline
Old 08-18-2005, 09:01 PM   #2 (permalink)
Re: Lock actuators
partsexpress.com has a various actuators. They must be adapted to fit onto your door lock arm. There are instructions on how to do this on this site, do a search for door actuators. At partsexpress.com do a quick search for "door locks". Monte
2000 250 PSD,CC,LB, Fuel pump mod,Gauges,AIS,BTM, 203 T-stat,DP-Tuner 40hp tow reflash, Air lift air bags.
2005 31RL Colorado 5th wheel
montegill is offline
Old 08-19-2005, 09:18 AM   #3 (permalink)
Re: Lock actuators
you can get them here:
www.commandoalarms.com
Baybear
'00 Lariat PSD CC, SRW, 4X4, 3.73LS, Auto, ESOF, Island Blue, NVK4, Diesel Innovations 4 position chip, VDO guages, Powershot 2000 propane, Mag-Hytec diff and trans pans, BBtriflo exhaust, Bob Riley IDM mod, Racor pre-filter, HX mod, in tank mods, DI regulated fuel return, BTS trans, AFE stage 2 intake
Baybear is offline
Old 08-19-2005, 12:08 PM   #4 (permalink)
Re: Lock actuators
Ditto on the Parts Express. I used these $4 unit in my crew cab all around. Work great, and dirt cheap!
Rob
2000 Ford F250 PSD Crew SWB 6 Speed Manual (138k)
2000 Jetta GLS TDI (106k)
1997 Passat TDI Sedan (137k)
Rob_from_Elkmont is offline
Old 11-19-2005, 07:06 PM   #5 (permalink)
Re: Lock actuators
Rob
Rob;
Do you just add these new actuators to the system without removing the old ones?
Pat Garcia – Huntington Beach, CA 99*F350*PSD*CC*4x4*LWB*DRW*White*XLT*TT*Auto
Pat@Escrow.net
Pat Garcia is offline
Old 11-25-2005, 06:24 PM   #6 (permalink)
NCHornet's Avatar
Re: Lock actuators
If you use the generic ones you have to splice into the harness and rig up a way of mounting them in the door. I just had to do my two front actuators and I opted to spend the money and buy theactual replacement one from Fordpartsonline for $40.00 each. I really don't understand why they are so much money and why Ford did not recall them. I was asked to write the replacement procedure for the FAQ section but don't know if it ever got posted. I didn't like the idea of cutting into my harness and mickey mousing a mounting place for the cheaper ones. The new Ford ones are much stronger than the stock ones. If you can't find the procedure just PM me and I will send it to you.
Kevin L. Mnt Airy, NC.
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 11-25-2005, 06:43 PM   #7 (permalink)
Re: Lock actuators
It's like 8-10 different sections in the manual to figure out how to change out one of these. I've been going to copy/cut/paste the procedure in to one document but never got around to it.
F-350 08 PSD CC Long Bed. Auto, 3.73, Dark Shadow Grey, Line-X, LT275/65R20 BFG Goodyear Wranglers, Leer Canopy. 2 German Shorthaired Pointers riding shotgun.
Stroked & Stoked is offline
Old 11-26-2005, 01:15 PM   #8 (permalink)
Re: Lock actuators
Thanks for the replies, now that I have taken the door latch assembly apart I can see that the original actuator can be separated out of the system. The new after market one could be hooked up to the same location via the supplied rod. The actuator itself would have to be mounted in a new (custom) location. The old or original actuator is integrated into the door latch but is a separate part. Not knowing what I know now I may have gone with the cheaper after market version, but I have already ordered the original replacements from a Ford supplier online.
I think that you could hook up the new after market actuator and probably leave the old one in place, that way you would not have to remove the latch assembly. You would just hook up the rod somewhere along the existing rod that runs across and up the door. Because of the design of the stock actuator there is little resistance.
Also one last thing, I dissected the actuator that I had already removed and the problem was that the small electric motor inside had failed; everything else inside was in good condition. (Springs and plastic gears)
Pat@Escrow.net
