Long time lurker.... First time buyer - Diesel Forum - TheDieselStop.com
Old 03-23-2005, 06:16 PM   #1 (permalink)
I have finally been able to purchase my first diesel! I have been watching these forums almost since there inception. It's good to finally be able to participate. Man these things are hard to find with low miles at a reasonable cost. Anyway........
You can see the truck I purchased here:
http://cgi.ebay.com/ebaymotors/ws/eB...76865&rd=1
I did have an independent inspection; however I'm not entirely sure that they knew a ton about Diesel's. I had them check the turbo and air cleaner for dust and a few other things I've read here. I'm interested in what some of the more experienced guy's here recommend checking and doing as soon as I pick it up? So far I'm planning on servicing the cooling system, thinking about fuel modifications, changing dif. and transmission fluid, and a couple other little things. Anyone have any other suggestions and comments?
I know a couple guys have access to the Ford service records, if someone wouldn't mind checking on this VIN I would appreciate it.
Thanks in advanced for any info you can share!
Mike
mgrothe is offline
Old 03-23-2005, 07:33 PM   #2 (permalink)
Re: Long time lurker.... First time buyer
aspen_leaf,
First welcome, and congrats on your purchase. I'm not even close to being an all knowing guy on diesels, but I would check the brakes for uneven wear. Change the tranny fluid. Check for debris in your intake yourself, a white rag helps alot. Ball joints, tire wear, chnage the fuel filter, and change the oil.
I'd first add gauges, then intake, exhaust, and then chip. Just my experience. other people will chime in with thier recommendations.
Just remember to have fun with your truck, that's the most important thing.
David, [img]/ubbthreads/images/graemlins/smokin.gif[/img]
99.5 f250 XLT PSD CC SWB 4x4 K&N FIPK, 305 Nittos,
Sirius, X code springs, Clear marker lights, clear corners, PF rotors and pads, 4" Down Pipe, and 4" moto blue stainless exhaust, Rancho RSX, Kenwood Head unit, 6 Disc Changer, which I haven't used since I got Sirius, and some other stuff
Shakes66 is offline
Old 03-24-2005, 11:15 AM   #3 (permalink)
Anyone able to look it up?
mgrothe is offline
Old 03-24-2005, 11:58 AM   #4 (permalink)
Ran an Oasis
No open campaigns
Less than two Dealer AWA repair visits
Warranty start date 10/28/00
build date 3/6/00
7.3L Turbo - DI
ZF M6HD-C 6-Speed Trans
No adverse information.
Hope this helps.
Ed Miller
isellford is offline
Old 03-24-2005, 12:07 PM   #5 (permalink)
Thanks Ed. Appreciate the info.
-Mike
mgrothe is offline
