Loud Vibration - Diesel Forum - TheDieselStop.com
Old 10-07-2008, 09:52 PM   #1 (permalink)
Loud Vibration
I have an 03 F350 crew cab with a 6in lift. I just replaced the ball joints about 2 weeks ago and I started to notice a vibration. I thought I found the cause of it to be the 4x4 auto locker sticking so I removed it and the bearing was completely seized. Instead of immediatly replacing it due to time to go and get it I just removed the guts of it and put it back on. The vibration still occured and I thought it then would be the wheel bearing. I now have just replaced the wheel bearing (which the small bearing was completely shot in it) and the 4x4 locker too and the vibration is still there. I am all out of ideas. I checked the u-joints on the rear and they are fine no play and everything seemed prettty tight. The vibration is virtually nonexistant at speeds under 45km and progressively get louder to about 90km and then it smooths out, but the vibration is still there. its pretty loud. I am OUT OF IDEAS????
Thank you to anyone that can help me
I also thought it may be the disc so I drove it again and applied the brakes the vibration was still there even with the brakes on slightly.
Scott F350 is offline
