Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 09-11-2005, 09:17 PM   #1 (permalink)
Scottz's Avatar
Lube brake caliper pins
What is a good lube to use on the brake caliper pins? I have heard stories about these things siezing.
2000 F350 7.3, Auto, Lariat. John Wood modifications: transmission, Airdog, ITP reg return, AC single shot injectors, DP Tuner, live tuned.
2005 F350 6.0 work truck
2007 Forest River Wildcat 29RLBS
Scottz is offline
Old 09-11-2005, 09:42 PM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Re: Lube brake caliper rails
Hi Temp Silicon Brake grease
haul_n_horses2 is offline
Old 09-11-2005, 09:48 PM   #3 (permalink)
JimmyDee's Avatar
My Photos: (24)
Can be purchased at Autozone in small tubes for a couple of dollars or a large, life time supply, plastic jar for about $10
Jim
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod; 4" Exhaust, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in Dash; AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is offline
Old 09-11-2005, 11:14 PM   #4 (permalink)
Scottz's Avatar
Thanks. Tips on using it? Do I have to remove the calipers?
Scottz is offline
Old 09-12-2005, 06:35 AM   #5 (permalink)
My Photos: (17)
Jack suggested the following: Open the bleed valve and compress the piston to bleed the water saturated and oxidized(?) discolored brake fluid. Remove the upper caliper pin rotating the caliper on the lower pin. Clean the upper pin and relube. Clean the bore in the caliper. Replace the upper pin. Now do the same for the lower pin. Calipers never come off and there is no danger of mixing the upper and lower pins up. It is useful to rotate the pins 180º ie. clockwise or ccw, so they wear evenly.
Old 09-12-2005, 10:36 AM   #6 (permalink)
Scottz's Avatar
Ok thanks. Already changed the fluid so I'll just re-lube the pins.
Scottz is offline
