Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 01-02-2006, 10:21 AM   #1 (permalink)
Lug nut torque specs please??????
Does anyone know what the torque specs are for lug nuts!! Thanks in advance
jclaude
Future upgrades:
Favorite Quotes
"You Can't Complain If You Don't Vote!" Me
"Candy is dandy but liqour is quicker!" Ogdon Nash
jclaude is offline
Old 01-02-2006, 10:30 AM   #2 (permalink)
Re: Lug nut torque specs please??????
165 Ft/Lbs. Do not torque it down all at once. Break it up into several increments for a last tightening torque of 165 Ft/Lbs. Remember to use a star type pattern so the wheel will be tightened evenly. Apply a small amount of oil to the washer of the lug nut only to keep it free moving.
"Real Trucks Don't Have Spark Plugs"
2000 F250 Lariat Crew Cab, Island Blue/ Harvest Gold , 7.3 PSD, LWB, 4x4 ESOF, Auto Trans. 3.73LS, 285/75/16,AT/BFG, Husky Liner Floor Mats, AIS/Foam Fender Sleeve Mod. Line-X, Leer 100XL Cap, MOOG Balljoints, Performance Friction Rotors and Z Rated Carbon Metallic Pads, Fumoto Valve, DIPricol Optix Gauges, Pyro,Trans,Boost, A-pillar Pod, MBRP 4 inch T-304 SS Cool Duals, EBPV delete 6.0L Trans. Cooler,Schaffer's Transmission Fluid, BTS Transmission, DP Tunes, Stock/High Idle/40T/60T/80E/120R/140SMK 309.77 hp/605.12tq
Spooling and Cooling by BWD with a Turbonetics Turbo & Spearco Big 6.0 IC
"The Smoke Don't Mean Its Broke!"
Bushwakd is offline
Old 01-02-2006, 10:34 AM   #3 (permalink)
Future upgrades:
Favorite Quotes
jclaude is offline
Old 01-02-2006, 03:49 PM   #4 (permalink)
NCHornet's Avatar
I would check your manual as I thought it was 150lbs? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Kevin L. Mnt Airy, NC.
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 01-02-2006, 04:39 PM   #5 (permalink)
My manual for my 03 states 150-165 ft.lbs.
Ed [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2003 F-350 Lariat Supercab 158" WB, 3.73 LS axle
7.3 PSD, auto trans. camper pkg. 12,500 lb. hitch,
adj. pedals. roof lights, Toreador Red, Arizona Beige, Power telescoping mirrors, and C-Betr mirrors. Delivery date Aug. 5, 2002. Reese 16K hitch, Thor Citation- model 29 5P 5th. wheel, Rhino liner.
2003f350 is offline
Old 01-02-2006, 04:58 PM   #6 (permalink)
Subman's Avatar
I was mailed a supplement that changed the torque to 165 footpounds.
Here's a little reading from the past.
web page
2002 F-250 S/C LB, Auto, VDH5, 3.73LS, My Truck
Complete fuel mods, coolent filter, Heater Cutout Valve, Walker BTM, Gauges(Pyro,Water,Trans), Jody's Econo tuned PCM, Turbo LifeSaver, AIS Severe Duty Filter Kit, Dahl filter and CCV Reroute to exhaust pics. CCV to exhaust since 4/27/03.
Subman is offline
Old 01-02-2006, 07:51 PM   #7 (permalink)
H2OWALL's Avatar
My Photos: (9)
I agree with bushwakd 165 ft/lbs I always have to refer to the manual for the first wheel to get the order right. The order is: "1-top, 2-bottom, 3-right, 4-left, 5-bottom right, 6-top left, 7-top right, 8-bottom left”.
I always get the first 4 right but get fuzzy on the last 4. I usually start with the 20 in/lb setting on my drill driver when putting the lugs back on, then 30 ft/lbs, 80 ft/lbs, 120 ft/lbs, and then 165 ft/lbs. I cringe every time I go to a tire shop and watch them just go in a circle around a wheel with the impact wrench.
I even asked the first time I got tires on my truck if the mechanic new the torque settings and tightening order. I should have watched. The week after I was taking the rear wheel off for something and 1 lug nut was finger tight and that got me curious so I got my torque wrench and checked the others, ranged between 30 ft/lbs and 80ft/lbs. Never went back there and I watched very closely the next time I got tires.
H2OWALL, 2003, 7.3L, F350, FX4, SC, Lariat, 6spd, 3:73LS, Prepump Mod, Harpooned, Royal Purple ATF, Warn Prem Hubs, BF Goodrich All Terrain TA/KO 305/70/16, MBRP 4" turbo back exhaust, DP Tuner- Stock, 40, 80, 120. DiPricol Optix Gauges- Boost, EGT, DIY Tymar, Sirius radio, Turbonetics.
A bad day on the water is still better than a good day at work. dwhyland on webshots
H2OWALL is offline
Old 01-03-2006, 09:24 AM   #8 (permalink)
NCHornet's Avatar
Is there a different setting for a 2000 dually??? I know I read to stop some of the wheel vibration to retorque the wheels to 140-150 ft lbs and it does seem to work. Please clarify this.
White Stroker
NCHornet is offline
Old 01-03-2006, 09:42 AM   #9 (permalink)
I thought I'd muddy the water a bit more and say that on the lugnut's washer (at least on my truck) it says "150 ft/lb".
2003 4x4 F-250 136,000+ Miles, 7.3L, Standard Cab, 6-Spd Handshaker. Bought used 09/04. Fold over gooseneck ball. Billet Grill insert. Open Element Intake (Baldwin PA2818). Bob Riley coolant filter, HPX hose, AIH Plug & 203* T-stat. SCMT-1705 on Tow Safe. Gauges: Air Pressure, Boost, & Pyrometer...more to come. MBRP Exhaust. Winter front by Alaska Tent & Tarp
TheLoneRanger is offline
Old 01-03-2006, 12:41 PM   #10 (permalink)
Always check your owner's manual for the correct spec & procedure. I don't think you're supposed to put oil on them, but some anti-seize lubricant is OK.
Walk softly & carry a BIG SIX !
Steve83 is offline
Old 01-03-2006, 03:40 PM   #11 (permalink)
H2OWALL's Avatar
My Photos: (9)
Quoted from pg 167 of my 2003 Owners Guide: "On all two-piece flat wheel nuts, apply motor oil between the flat washer and the nut. Do not apply motor oil to the wheel nut threads or the wheel stud threads."
H2OWALL is offline
Old 01-03-2006, 03:55 PM   #12 (permalink)
You are right, that is how many bolts are broken or deformed. With coarse threads one should multiply wet, lubricated, torque by a factor of .6 So if the threads were lubricated, wet, then the max torque would be 165# X .6 = or 99 lbs. If you lube them and then torque to 165# then that is 165 x 1.4 = the equivalent of 231 lbs, over-torqued could pop the stud. Might be useful information for someone that has a torque wrench that doesn't go to 165#. 106
Oneof6 is offline
Old 01-04-2006, 02:13 AM   #13 (permalink)
There was an update to the 2000 I recived in the mail it said to go up to 165 and add the oil.
DENNY
1999 F350 CC SRW LB 4X4 SIX SPEED.
DENNY is offline
Old 01-04-2006, 12:50 PM   #14 (permalink)
Boy nothing is simple is it. To much or not enough torque and you can damage the rotors. Now throw in some never seize on the threads and your really out in space. Guess I'll clean mine off and leave them dry to be safe.
2000 F250 4X4,CC,SB,AUTO
Powered by some bolt on stuff from
BEANS and BTS, #2 only
463HP 991TQ 10/01/05 mustang dyno 10k rollers
458HP 923TQ 04/14/07 Dynojet dyno
GPorter is offline
Locate Ford Dealerships to find a new Ford for sale,
